Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-09-2012, 06:28 PM   #1
building firplace
Does a gas fireplace need a full chimney or can I use a standard 6" exhaust pipe out of the wall? This fireplace will be in the basement.
jbillups is offline   Reply With Quote
Old 02-09-2012, 10:17 PM   #2
building firplace
You need to follow the manufacturers specifications. In other words, step one is deciding on the fireplace, not installing venting.
hvac benny is offline   Reply With Quote
Old 02-09-2012, 11:12 PM   #3
building firplace
Not even sure what you mean by standard 6" pipe. That could mean single walled, double walled, triple walled.
Most use a very expencive pipe that draws in fresh air for combustion and vents all in the same pipe.
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 05:04 PM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 09:47 PM
Effect of Heat Load of Tenants on a Commercial Building mphoenix HVAC 1 04-20-2011 04:59 AM
Siding on utility building Angela3511 Building & Construction 5 04-18-2011 08:28 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
