Building In Back - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-14-2013, 02:38 AM   #1
Building in back
I have a building in my back yard that is level with the ground. Water builds around the bottom and it leaks inside. I thought about ripping inside walls out and place a 2x4 on studs at base, on inside wall and filling with quick dry cement between studs. Would this work to stop the leak or would it do more damage?
whitneyt1982 is offline   Reply With Quote
Old 03-14-2013, 07:36 AM   #2
Rewards Points: 4,794
building a moat around a below-grade bldg rarely adds to the dryness of anything,,, either raise the bldg ( bodacious BIG crowbar ) or improve the drainage,,, this may req you to install a rock-fill'd & soil cloth lined swale, a sump, pump, or gravity drainage to a low point.
need to also consider the dumping out point - its often illegal to create a hazard on the giftee of your discharg'd wtr
Old 03-14-2013, 08:14 AM   #3
Rewards Points: 14,294
Need a picture!
Adding Flooring/Drywall/Insulation in Portable Storage Building Ashley DIY Building & Construction 0 07-12-2012 10:06 PM
Building a basic in-wall bookshelf. Need help with fasteners and design. Lavid2002 Carpentry 16 06-04-2012 11:36 AM
Progress on Storage building, more slab questions. J S Machine Building & Construction 18 05-07-2010 07:30 AM
Building a temporary workshop inside of large pole building HandyDave Building & Construction 0 02-17-2010 08:39 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
