Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-20-2012, 06:26 PM   #1
Bricking up a fireplace
Hi
I have removed a gas fire and I was wondering the best way to close the hole up. Not thet good with DIY. Would rather use plasterboard than bricks.
Do I need a vent in it ?
Thanks.
dagutter is offline   Reply With Quote
Old 04-21-2012, 03:36 AM   #2
Bump please
Old 04-21-2012, 05:08 AM   #3
Yes you do need a vent, and also at the top or you may get dampness in the chimney breast.
stuart45 is offline   Reply With Quote
Old 04-24-2012, 08:40 AM   #4
Cap the top of the chimney to eliminate any possibility of water damage. This will eliminate the need for any vent.
TRUEPRO is offline   Reply With Quote
Old 04-24-2012, 10:43 AM   #5
If dagutter is in the UK, which he probably is as he said plasterboard, the chimney needs to be vented with an air brick at the bottom and a terminal like this at the top.
How to go about replacing fireplace surround? NewHomeDIYGuy Remodeling 9 01-26-2012 10:56 PM
Need opinions on tearing out old fireplace Dwillems Building & Construction 9 09-06-2011 12:37 PM
Fireplace construction question scottyv81 General Discussion 1 01-29-2011 10:26 AM
Fireplace Smell ...help wanted ! jasonb72 General Discussion 6 08-26-2010 07:02 PM
Possible to build direct-vent fireplace? DIYerself General Discussion 3 12-22-2007 11:07 PM
