Brick Wall On Front Of House Is Leaning - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Closed Thread
Old 05-02-2009, 05:01 PM   #1
brick wall on front of house is leaning
hello,
I was hoping someone would have some ideas on fixing a brick wall. We have a 3 or 4 foot wall on the front of ours house and part of it is cracked and leaning out. the wall looks like it may have falling down off its foundation a little, there is about a foot of cement in front of the bottom, it looks like it has fallen a little behind it like part of the foundation gave note: not the house foundation the form for the wall. we went to lowes and the guys idea was to use f26 construction glue and push the wall back - well we tried to push and it was not going to move. we would rather try to fix it, rather than replace it right now with the way the economy is.
anyone have any ideas
thank you
Brenda
Brendawyatt is offline
Old 05-02-2009, 05:09 PM   #2
Chicago, IL
Michael Thomas's Avatar
Can you upload a picture to one of the free hosting services and then link to it here?
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline
Old 05-03-2009, 08:53 PM   #3
Rewards Points: 91
Flagging this to watch the thread. I have a similar problem but concealment is not an issue.
Allthunbs
Allthunbs is offline
Old 05-03-2009, 11:08 PM   #4
It sounds like you have brick veneer siding that was set on an inadequate footer. It may be possible to higher a foundation jacking company to jack it up and stabilize the footer but would probably be cheaper top tear off and redo or tear off and replace with siding.
hayewe farm is offline
Old 12-03-2012, 07:28 AM   #5
Foundation repair guy
Brick falling off
A picture would help tremendously... But if its real brick, and bowing out, a cheap, temporary fix is installing 3" wide vertical steel plates every 3-6' (depends how bad the wall is). It won't look very good but should hold it in place until your ready to rebuild the wall
Removed link to company website
Last edited by beenthere; 12-03-2012 at 08:35 AM. Reason: Removed link to company website
Blueprintbuilds is offline
Old 12-03-2012, 08:12 AM   #6
Rewards Points: 1,294
You do realize this is a three year old post...OP is probably no longer watching
Last edited by beenthere; 12-03-2012 at 08:36 AM. Reason: Removed link to company website in quote
danpik is offline
Old 12-03-2012, 08:38 AM   #7
An old Tradesmen
Rewards Points: 6,550
Blueprintbuilds.
Please read our site rules, including advertising rules, ("Participants may not include their company name as part of their username")
thank you.
Old thread. Thread closed.
beenthere is offline
Closed Thread
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
New opening in a brick veneer wall - installing new brick ties? GrantJohnson Building & Construction 3 01-28-2009 11:17 AM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 06:42 PM
Care of Brick front sherlock General DIY Discussions 2 08-12-2005 07:41 PM
