Brick Wall - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-23-2013, 06:02 PM   #1
Rewards Points: 20
Brick wall
Thinking about rehabbing an old house. There is a lot of structural damage to the brick at the back of the house. It leaking water all in the house every time it rains hard.I never laid brick before and would like to learn it. So my question is, how hard is it to repair brick in a wall?? Any advice would be helpful.
Brick wall-image-1775444859.jpg   Brick wall-image-652709056.jpg   Brick wall-image-984734415.jpg
Delvia Carter is offline   Reply With Quote
Old 11-23-2013, 09:32 PM   #2
Rewards Points: 13,724
Call a real mason on this one and a structural engineer.
There's some major structural failure going on there, not just some loose brick.
Old 11-24-2013, 03:32 AM   #3
Rewards Points: 502
Looks like there has been failure of a beam somewhere lower down. Perhaps an opening within that cheap-looking extension has been opened up and no proper beam installed?
Definately not a DIY job if you've never laid a brick before.
tony.g is offline   Reply With Quote
The Following User Says Thank You to tony.g For This Useful Post:
Delvia Carter (11-24-2013)
Old 11-24-2013, 04:46 AM   #4
Just a guess from what I've seen before.
Window sill rotted out from lack or mantaince.
Water leaks down the wall.
Outside rim joist and wall studs rot.
Building falls down.
Old 11-24-2013, 08:23 AM   #5
Rewards Points: 1,232
That can easily be fixed with a bulldozer.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
The Following User Says Thank You to Tscarborough For This Useful Post:
Old 11-24-2013, 01:37 PM   #6
Rewards Points: 20
Thanks for the advice. On a guess what do you think this would cost to fix??
Old 11-24-2013, 04:17 PM   #7
Guesses on cost are just not going to happen on any web site. If someone does come up with a price it's worth what it cost.
You need someone on site.
Unless your getting this property for what the lot would cost and you have very deep pockets I'd pass.
There's just far to may other property's out there that would need far less structural non DIY work available to waste time on this one.
Old 11-27-2013, 06:15 AM   #8
Rewards Points: 4,656
i wouldn't want to be learning brickie work on a 1st job like this,,, depending on the price, there may be $$$ opportunity here,,, best advice so far's the pe & brickie 1st altho t-scar's post does have merit, too
Old 11-27-2013, 06:56 AM   #9
Rewards Points: 1,296
Really need to see a picture of what is under that window inside that porch. As was mentioned the real illness is lower down in the building. The symptom is just showing up below that window. as far as cost to repair, >$1.00
danpik is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
My garage wall bricks seems to be cracking where the brick wall contacts Unicornz0 Concrete, Stone & Masonry 2 09-05-2012 09:31 PM
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 12:26 PM
Concrete Plaster coat Mix ratio needed, for brick interior wall. Spud Concrete, Stone & Masonry 6 07-08-2012 01:55 PM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
