Brick Veneer Over Scratch Or Brown Coat? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-09-2013, 07:25 PM   #1
Rewards Points: 452
Brick veneer over scratch or brown coat?
I plan to remove the existing brick wall.
I'm pretty sure there's only a scratch or brown coat under it.
so I can stick brick veneer with exterior grade thinset mortar directly on that, right?
Does veneer need to be anchored to the wall with anything other than mortar?
pman6 is offline   Reply With Quote
Old 01-09-2013, 07:31 PM   #2
Concrete & Masonry
Rewards Points: 470
Are the existing brick actually clay thin-sawn brick?? If so, yes, the substrate "should" be fine, as long as you don't cause too much damage getting the existing brick off. If the brick are faux, like a fiberglass substite or the sort, all bet's are off........
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
concretemasonry (01-09-2013)
Old 01-10-2013, 03:43 AM   #3
Rewards Points: 452
I don't really understand your question, but they look like real antique bricks to me.
They stick out past the window about 3-4 inches.
House was built in the 1960's, so 99% chance they are real bricks.
Old 01-10-2013, 08:25 AM   #4
Concrete & Masonry
Rewards Points: 470
If they're real full veneer brick, I doubt there's a scratch coat behind it.
Are the new brick going to be a full brick as well? You don't "stick" full brick to a wall, you stack them and let gravity and wall ties take over............
Old 01-10-2013, 10:14 AM   #5
Rewards Points: 1,220
"Veneer" is a relative term. An adhered veneer sticks to the wall, which would be scratch/browncoat. Traditionally, "Brick Veneer" means full size (3-4" thick) that are set on a brick ledge and tied to the back up wall with brick ties. There is normally an airspace between the veneer and the backup wall.
What you have is almost 100% a traditional brick veneer.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
veneer brick IvanR Building & Construction 0 01-21-2011 11:47 AM
Replacing band joist behind brick veneer jzambon Building & Construction 0 03-09-2010 12:58 PM
Cracks in stucco scratch coat - is this normal? chadurban Building & Construction 5 05-25-2009 11:55 PM
Mounting Plasma TV on Brick Veneer Bob_Alias Remodeling 3 01-29-2007 07:14 AM
Mounting Plasma on Brick Veneer Bob_Alias General DIY Discussions 1 01-03-2007 09:53 AM
