Brick Question - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-19-2013, 02:56 PM   #1
brick question
Hi,
When you have brick siding do the bricks begin on top of the footing or the foundation wall just below grade?
markharmon is offline   Reply With Quote
Old 06-19-2013, 03:59 PM   #2
Rewards Points: 3,722
Originally Posted by markharmon View Post
Hi,
What do you mean by "brick siding" ????
Canarywood1 is offline   Reply With Quote
Old 06-19-2013, 05:18 PM   #3
joed's Avatar
Rewards Points: 13,322
The brick begins on top of the foundation on the brick ledge ABOVE the grade.
The Following User Says Thank You to joed For This Useful Post:
creeper (06-19-2013)
Old 06-19-2013, 05:41 PM   #4
no its not above grade. Good try.
Old 06-19-2013, 05:42 PM   #5
brick siding just what I said!
Old 06-19-2013, 06:41 PM   #6
Bricks are not meant to be below grade. Blocks??
creeper is offline   Reply With Quote
Old 06-19-2013, 06:43 PM   #7
Concrete & Masonry
Rewards Points: 620
If you're referencing a conventional brick veneer, most of them start at a brick ledge 8" below the top of foundation, but there's only one way to verify for sure: a shovel. The most conventional approach is shown in figure 3 (a):
http://www.gobrick.com/portals/25/do...notes/tn28.pdf
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
Windows on Wash (06-19-2013)
Old 06-19-2013, 08:07 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 1,964
Brick siding....as in siding that looks like brick? Why? Why not the real thing?
Old 06-20-2013, 08:21 AM   #9
And is that brick ledge part of the foundation wall?
Old 06-20-2013, 08:36 AM   #10
Old School
Willie T's Avatar
Here is some more stuff from the forum on this.... Brick veneer is 4 rows below grade- redo or leave?
Willie T
Old 06-20-2013, 08:44 AM   #11
Concrete & Masonry
Rewards Points: 620
Yes.
The most common way to construct a brick ledge "here" is to lay an 8" wide block on the last (top) course of the wall, on top of the 12" block below.
In poured walls, a 4" (or more for stone sometimes) wide "box" is constructed in the top of the wall with either lumber, foam, or both........
Old 06-20-2013, 12:44 PM   #12
Yes.
so a 4" ledge on top of the existing 8" thick foundation wall? On the bottom of the bricks on the first course you have to have a through wall flashing, right?
Old 06-20-2013, 02:23 PM   #13
concretemasonry's Avatar
Rewards Points: 2,626
Real brick is 3-5/8" thick (modular) or slightly less if bought by a cheap builder.
There are several categories of brick exteriors.
1. True veneer using real brick and laid with an air gap behind (3/8" up to the Cadillac cavity wall with a 2" air gap and weeps). The air gap is to provide drainage/ventilation and prevents the back-up for being exposed to wind-driven rain with the brick and the air gap.
2. During initial construction, brick can be bonded into the bearing part of the wall during construction, so the brick ends up being bearing along with the wall materials. This does offer the advantage of an air gap.
3. Very thin brick that is cut to the desired thickness or made very thin (rare) and is bonded to the wall and does not really contribute to the strength and does not provide an air gap..
You can also lay a 4" or 6" concrete block on the footing that projects beyond the bearing foundation wall. You can step the height of the of the veneer. Cheaper and faster than running the the brick up from. Obviously a brick veneer is not loadbearing, but this way it sits on. In some ares of the country concrete block are made with 4" wide projection (brick ledge) on the top (as laid) and beveling down to 8", 10" or 12" to decrease the thickness of the lower portion of the wall and the brick may be considered as part of the bearing wall.
Unfortunately, not enough information is given on the construction status, so specific solutions cannot be offered. I assume you have or will have an 8" wall, but in many areas of the world 6",8",10",12",14" or 16" thick block are used for high strength load bearing walls (how about 6" partially reinforced bearing walls for 20 story buildings using U.S. codes).
Dick
concretemasonry is online now   Reply With Quote
Old 06-20-2013, 03:38 PM   #14
GBrackins's Avatar
Rewards Points: 2,108
how 'bout a photo or two of what you have?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 06-20-2013, 08:42 PM   #15
joed's Avatar
Photos. We need photos.
Any siding, brick veneer, brick siding, vinyl, wood etc. should be a minimum 8" above the grade.
Brick Jack Arch - options for cutting brick PAbuilder Concrete, Stone & Masonry 4 01-30-2013 07:00 PM
question about brick patio base vipergtsxz Landscaping & Lawn Care 5 06-30-2012 02:17 PM
question about an old brick chimney DIherself Roofing/Siding 1 04-27-2011 11:16 PM
Exterior Brick Wall with No Sheathing? beesan Building & Construction 1 12-08-2009 05:57 AM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
