Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-10-2012, 08:33 PM   #1
Brick Planter against Block Fence
So we build a patio in the backyard and are about to put in a block wall using regular 4x8x16 block. What I'm wondering is if we build a brick planter about 2 1/2 or 3ft high, about roughly 20 or 24 inches deep and about 16ft long it leaves me with a few questions.
1: Can I just use the block wall as the backer for the planter?
2: What would be the best option for brick, do I need specific sizes or would a standard 4" brick work for the layers of the planter wall to support any issues with the weight of the dirt?
clm1983 is offline   Reply With Quote
Old 03-15-2012, 12:16 AM   #2
I would love some advice on this too! I live in the desert and really need some planter advice!
Tiff in Vegas is offline   Reply With Quote
Old 03-15-2012, 08:05 AM   #3
If you are going up 3ft I would build it as an 8 inch wall in Flemish bond.
stuart45 is offline   Reply With Quote
Tags
block wall, block walls, brick planter, planter, planters
Brick separating from the block Kxlara General Discussion 3 01-03-2011 11:26 AM
Backyard Fence (Part 1) biggidybankston Project Showcase 20 12-05-2010 12:44 AM
Largest Crown Molding Cut on DeWalt 716 Klawman Carpentry 8 11-14-2009 09:05 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 07:41 AM
block and brick Toolmaster Building & Construction 7 08-31-2009 01:57 PM
