Brick Patio Install Gone Wrong - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree20Likes
Old 12-27-2016, 03:44 PM   #16
Rewards Points: 83
Re: Brick patio install gone wrong
Originally Posted by jomama45 View Post
Maybe it's just the picture fooling me, but are half of the brick laid on bed (normal for a paver) and the other half laid on their side (normal for a wall)??
Not sure why you'd want pavers over concrete and mortar WITHOUT mortared joints keeping the water out. It appears you're in a cold climate, not a great place to let all of that water seep under the brick and freeze.......
They are all laid flat, but there was supposed to be no gap and then polymeric swept into the cracks. I pulled the brake before they could do sand.
de-nagorg likes this.
Bubbagump is offline   Reply With Quote
Old 12-27-2016, 05:49 PM   #17
" I Can Fix It "
Mrbuilder's Avatar
Rewards Points: 158
Depending on brick Ron, this pattern can be laid without cutting any...........
Msradell likes this.
" It's ok if you're not sure, find someone who is"
Mrbuilder is offline   Reply With Quote
The Following User Says Thank You to Mrbuilder For This Useful Post:
jomama45 (12-27-2016)
Old 12-27-2016, 06:01 PM   #18
" I Can Fix It "
Mrbuilder's Avatar
Rewards Points: 158
Check these patterns... https://www.google.com/search?q=herr...HYQ0BgoQsAQIMA
Old 12-27-2016, 07:45 PM   #19
Rewards Points: 436
Add a ll of the bricks, divide by four, and that is likely the number of brick sections that you will need to fill in the edges to get clean lines. Ron
ront02769 is offline   Reply With Quote
Old 12-27-2016, 07:56 PM   #20
Concrete & Masonry
Rewards Points: 568
OK, it must be an illusion then. I still can't understand why they'd go through the trouble of wet-setting them in mortar just to use polymeric sand. Those brick are relatively uniform in nature, they would have laid flatter (and much easier, faster, and straighter) dry-laid on the slab. At this point, I don't know what other option you have than to persue them to remove them and try again.....
As a mason, I've laid plenty of brick patios, and even I have no idea what you're talking about.................
jomama45 is offline   Reply With Quote
Old 12-27-2016, 08:54 PM   #21
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,820
Originally Posted by de-nagorg View Post
HACK HACK.
That looks like it is many years old, with poor bedding, weight rolling all over it.
This is lousy installation, nothing more.
And you are going to get varying color in a batch, due to the materials not being consistently mixed at the brick works.
Make them re-do this. And this time NO ALCOHOL on site.
ED
I don't mean to derail this, but could you find out what they were drinking/smoking..... must be some good stuff... how'd they get home???
Yes... You're entirely right... that is krap.
MTN REMODEL LLC is offline   Reply With Quote
Old 12-27-2016, 10:01 PM   #22
Msradell's Avatar
Rewards Points: 210
??? The number of bricks you end up cutting to fill the edges is significantly less than that in varies by the size of the area you are doing. Obviously a long skinny area requires more cutting but even then if laid out correctly you should only be cutting half of the edge bricks and none of the center ones.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 12-28-2016, 06:36 PM   #23
Rewards Points: 1,232
Nice of you to pay someone to attempt to learn how to lay brick. Better pay him some more, he needs more practice. Better yet, do it yourself. You and your drunken friends would do a better job than that.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
remove bay window install patio door scotterickson Building & Construction 4 11-21-2011 07:52 PM
old brick patio preservation momof2labs Landscaping & Lawn Care 0 09-24-2011 07:19 AM
Patio install question patio22 Landscaping & Lawn Care 5 08-20-2010 07:53 PM
brick paver patio fishin dude Landscaping & Lawn Care 7 03-03-2010 11:10 PM
Redwood Deck Over existing brick paver patio areacode516 General DIY Discussions 3 04-12-2009 09:09 PM
