Brick Over Fireplace Clean-out - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-17-2014, 02:23 PM   #1
Engineer
Rewards Points: 161
Brick over fireplace clean-out
Hi all,
After experiencing a nasty draft in my living room today I tracked the problem to a damaged exterior fireplace clean-out door. It looks like I can replace the door, but we only use the fireplace with natural gas, and thus have no use for the clean-out. Could I brick the exterior door as well as the interior door in the bottom of the fireplace so the clean-out is permanently sealed? Even when functional it doesn't appear that the clean-out doors are very energy efficient. Does this pose any code issues, and would there be a need to fill the clean-out void with a non-flammable insulation material?
diystephen is offline   Reply With Quote
Old 02-18-2014, 12:51 PM   #2
Rewards Points: 1,232
Yes you can.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Cleaning & Sealing Red Brick JasonCA Concrete, Stone & Masonry 3 01-23-2013 11:56 AM
Suggestions on refacing brick fireplace Lynch Building & Construction 10 10-04-2011 07:33 AM
fireplace brick facades removal somaxim Building & Construction 3 07-06-2011 07:47 AM
Remove Brick Fireplace Clemsig07 Building & Construction 1 04-12-2011 08:59 PM
Drywall over a brick fireplace?? Mom2JoMoLa Remodeling 0 06-13-2010 09:21 AM
