Brick Mortar Replacement - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-14-2013, 02:42 PM   #1
Rewards Points: 16
Brick Mortar replacement
Is there an additive that will allow replaced brick mortar to remain some what flexible to absorb minor movement?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 11-14-2013, 05:00 PM   #2
Rewards Points: 4,448
mortar is somewhat flexible,,, if it weren't, every day when the sun hit the bricks & heats 'em, it compresses as brick expands,,, when it cools at nite, the reverse happens - bricks shrink / mortar expands ( despite what you're thinking, there's lots of air in mortar )
simple hi-skoul fizicks
Old 11-14-2013, 06:36 PM   #3
Rewards Points: 502
Doesn't that depend on how much cement is in the mix?
(richer mix = harder mortar an' all that?)
tony.g is offline   Reply With Quote
Old 11-14-2013, 06:55 PM   #4
Civil Engineer
Rewards Points: 4,514
Lime mortar is very flexible. It has mostly been replaced with cement mortar because cement mortar is stronger (not always a good thing) and cures much more quickly. It is still possible to mix your own lime mortar, however using lime mortar on part of a building, and cement mortar on another part, could be problematic. I defer to a mason on that question.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
concretemasonry (11-14-2013)
Old 11-14-2013, 09:53 PM   #5
Rewards Points: 3,348
Sakrete has a type S sand,lime,and portland cement in a bag,it's what your looking for,just add water.
Canarywood1 is online now   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
digitalplumber (11-14-2013)
Old 11-17-2013, 08:41 PM   #6
Rewards Points: 1,220
Type S is in no way suitable for tuckpointing most existing brick. Type N or softer is just fine, and a good mix would be:
Portland cement: 1 part
Lime: 2 parts
Masonry sand: 5-6 parts
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
The Following User Says Thank You to Tscarborough For This Useful Post:
digitalplumber (11-17-2013)
Old 11-17-2013, 09:14 PM   #7
Lime: 2 parts
Type N is fine if your exterior above grade or interior, otherwise Type S.
Old 11-17-2013, 09:22 PM   #8
Yes, well I didn't see where the OP said anything about below grade, but other than that or a very limited type of brick, Type N or softer will always be required, if not outright lime mortar. If you have any doubts or questions, I refer you to the Brick institute's Tek Notes 8b on the matter.
http://www.gobrick.com/Technical-Not...echnical-Notes
Old 11-17-2013, 09:58 PM   #9
I don't see where he said anything about above grade either,but each is an acceptable alternative either way.
http://www.cement.org/masonry/cc_mortar_types.asp
Old 11-17-2013, 10:10 PM   #10
concretemasonry's Avatar
Rewards Points: 2,566
Strength is really not a criteria for mortar selection. There are more important factors such as workability, band and usability. Even the specifications for mortar state that the lowest strength possible to carry the loads. Adding to that is the factor that compressive strength has a small effect of the actual strength of a masonry wall.
It is one of contradictions to the falicy that more is better.
Dick
concretemasonry is offline   Reply With Quote
Old 11-17-2013, 10:21 PM   #11
What it is, Dick, is the confusion between mortar and concrete. They are not the same, even though they share some of the same ingredients. As you well know, they serve totally different purposes and have totally different requirements.
Concrete is a cast material that relies upon it's compressive strength in some applications (slabs for example) and it's tensile strength in others (precast girders for example). Mortar is used to hold masonry units that are not prefect in their dimensions apart with the primary goal of being softer than the units, with a good bond strength, flexural strength and a degree of breathable waterproofing. Softer is always better, the actual compressive strength of any structural masonry wall will almost always be far lower than what is considered to be a modern mortar.
Frost Free Hose Bibb replacement through brick siding Morgan R Plumbing 1 03-12-2012 06:19 PM
brick wall window -- replacement review amakarevic Building & Construction 3 01-24-2012 02:48 PM
Painting Brick - not the mortar Dan-D Painting 3 03-07-2010 01:00 AM
Potential foundation issues oklahomaguy32 General DIY Discussions 7 02-14-2010 04:12 PM
Mortar or thin set for brick pavers bdawson General DIY Discussions 0 04-27-2008 02:44 PM
