Brick/Mortar Repair - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-03-2012, 03:13 PM   #1
Rewards Points: 156
Brick/Mortar Repair
House built in 1930. There a a couple areas where mortar repair is needed, but this area is the one that drives me nuts. Right at the front entrance.
I thought about chiseling or grinding out the old mortar and repointing the area. It looks as if the bricks have separated more than what is consistent on the rest of the house, so I don't know if this is an option.
Should I rip this area out and completely redo?
Brick/Mortar Repair-untitled.jpg
Branden is offline   Reply With Quote
Old 05-03-2012, 03:36 PM   #2
concretemasonry's Avatar
Rewards Points: 2,594
I don't think you want to deal with a foundation problem.
Grind out the mortar (do not chisel!!!) and tuckpoint the joints with an appropriate color mortar. The fresh mortar may appear dark initially and will lighten as it cures. If it seems to get too light, you can rub some soil on it and then rinse off later.
Dick
concretemasonry is online now   Reply With Quote
Old 05-03-2012, 04:29 PM   #3
Rewards Points: 502
As a point of interest, why do you suggest grinding out the mortar rather than chiselling? Even with a small grinder, wouldn't it risk damaging the bricks if he was a bit too enthusiastic? I know chiselling is a pain but I wonder if it would be safer. Or is it that the brick is a veneer over a timber frame and might work loose by chiselling? Just wondering.
tony.g is offline   Reply With Quote
Old 05-03-2012, 05:25 PM   #4
joed's Avatar
Rewards Points: 12,454
That crack looks to have been repaired once already. If you don't deal with the underlying problem it will come back again.
Grinding is usually much quicker and cleaner than chiseling.
Old 05-03-2012, 08:29 PM   #5
Once you start banging a brick veneer with a hammer and chisel, you never know what will come loose, be cracked or show up later.
Dick
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 06:42 AM
Repair 1962 Rheem pink toilet tank or find vintage replacement ? khaef Plumbing 0 09-09-2011 09:55 AM
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 12:42 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
