Brick Fence - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-24-2013, 11:28 AM   #1
Brick Fence
I have a couple of questions. I am looking at building a 5.5-6' tall brick fence does it need to be two bricks thick at a minimum? Does it have to have pillars or can it just be a wall? Any info would be grateful.
ruce22 is offline   Reply With Quote
Old 06-24-2013, 12:11 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
Thread moved- you might get better response here.
How long is the fence?
Have you designed a footing for it?
Are you in a cold climate? This will determine your footing depth.
Can you add your general location to your profile please?
Old 06-24-2013, 12:12 PM   #3
Old School
Willie T's Avatar
Call your local Building Department.
Willie T
Old 06-24-2013, 12:30 PM   #4
The fence will be 186'x189'x43' with two openings on the 43 foot side of 12' and 4' for gates. The general area is Tulsa, Ok and we are not in city limits so there is no real building department. I figure the footing will need to be at least 1 foot deep by 1 foot wide? I appreciate it.
Old 06-24-2013, 12:37 PM   #5
Old School
Willie T's Avatar
So, call Tulsa, and build it to their specs.
Willie T
Old 06-24-2013, 05:51 PM   #6
Rewards Points: 502
A wall that height would need to be 2 bricks thick minimum; you might also need stiffening piers at intervals, depending on your wind loading.
http://www.stgbc.org.uk/Downloads/GardensWalls.pdf
tony.g is offline   Reply With Quote
The Following User Says Thank You to tony.g For This Useful Post:
ruce22 (06-24-2013)
Old 06-24-2013, 11:18 PM   #7
Msradell's Avatar
Rewards Points: 128
Your footing probably also going to need to be deeper. Probably at least to the frost line depth in your area. As stated above it's definitely going to have to be to bricks thick with support posts and regular intervals, probably about 10'-12'.
Msradell is offline   Reply With Quote
Old 06-25-2013, 03:47 PM   #8
Thats what I was planning is 10-12' between post two bricks thick. I think I will need to tie the two walls together with ties? Any recommendations there? The wind can blow 40 MPH on any given day. The frost line is 10-15".
Old 06-25-2013, 04:54 PM   #9
Rewards Points: 502
Why use metal ties? Why not use a brick bond, such as English Garden wall bond? (one row of headers [bricks places across the wall] to every 3 or 5 strechers [bricks placed along the wall]).
http://paultaborbrickwork.blogspot.c...k-bonding.html
Old 06-25-2013, 05:11 PM   #10
I was thinking Flemish Bond or ties wasn't sure which would work best or be strongest? I would like to not have stiffening piers which I may not be able to do. How do I tie those to the wall sections? The fence is 43' x 189' x 186' x 109' I missed a dimension above. Was trying to get the best ideas so I can tell them how I want this wall built and feel good that it will last.
Old 06-25-2013, 05:35 PM   #11
Rewards Points: 502
Flemish bond is one of the most attractive bonds but is difficult to do. You have to make sure the header bricks (ie the bricks going through the thickness of the wall) are all in a vertical line, otherwise it looks bad.
If you're not used to bricklaying, plain strecher bond with metal ties (stainless, not galvanised) may be easiest. As to which is 'strongest', it doesn't strictly apply to low, free-standing walls because they don't carry much vertical load. But at a pinch, bonding the bricks - in whatever pattern - will have the edge.
At that height, you will probably need some stiffening piers at about 12-15ft centres. You may also need to consider some movement joints at intervals, as your walls are long.
Does your local building authority not give any guidance on boundary walls?
Although the manual work here is DIY-able, it may still be prudent to consult an SE on such things as the size of piers needed, the need for movement joints, and mortar-type etc. An SE will also be aware of local conditions, such as wind-loading.
EDIT; (sorry, didn't realize you were getting someone to do it, but still prudent to get advice rather than rely wholly on the bricklayers opinions).
Tags
brick , fence construction
Brick columns for wood fence dgb48 Concrete, Stone & Masonry 8 03-16-2013 06:41 PM
Cleaning & Sealing Red Brick JasonCA Concrete, Stone & Masonry 3 01-23-2013 12:56 PM
Reuse Concrete Fence Post Pier & Fence Post Extraction JasonCA Landscaping & Lawn Care 2 03-24-2012 09:58 PM
Brick Planter against Block Fence clm1983 Concrete, Stone & Masonry 2 03-15-2012 08:05 AM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 09:50 AM
