Brick Drive Way - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-29-2014, 12:04 PM   #1
brick drive way
I have section of(dirt& gravel and fill material) drive way that is up against a retaining wall (I want to improve). The area has been filled with crushed rock (concrete fill) with a layer of sand over the rock. I've removed some sand and tamped the sand flat.
I'm wondering whether I should lay crushed rock and stone dust and tamp again, and another layer of sand and screte before laying brick? Versus laying the brick down, concreting an edge and laying sand on top to hold the brick joint(s).
I am planing on a concrete edge on the brick driveway.
There isn't any house foundation to interfere.
Thankyou
jogr53 is offline   Reply With Quote
Old 03-29-2014, 12:28 PM   #2
Rewards Points: 2,834
Did you hand tamp, or machine tamp?
A driveway needs a very strong solid base to be able to support a vehicle.
It really needs the stone base locked together tight and that usually takes a mechanical tamping.
If you get it tightly locked than lay brick, then you just need to build the concrete edging, then sweep a sand mixture into the joints and run a mechanical tamper one more time , but use a piece of old carpeting under the plate to keep it from breaking the brick, or scratching I also.
de-nagorg is online now   Reply With Quote
Old 03-29-2014, 12:57 PM   #3
Hand tamped it is a two strip drive way or ribbon driveway. Not to much room for a machine tamp.
Thankyou.
Tags
brick , concrete , diy , foundation
wrought iron security door frame diy888 Windows and Doors 6 02-22-2016 07:08 AM
Brick veneer is 4 rows below grade- redo or leave? cbrc5eric Building & Construction 11 12-27-2011 08:09 PM
Expansion / Contraction 2x4 whitewood studs on brick bpardo Building & Construction 2 08-29-2011 02:22 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
