Brick Cracking On Lower Corner Of House - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-06-2013, 08:31 PM   #1
Brick cracking on lower corner of house
My all brick house is a little over a year old now. While I was doing some yard work today, I noticed a vertical hairline crack on the very bottom outside corner of one wall. It originates from the lowest point of the brick ledge and goes up about 8". The crack starts in the mortar and actually goes through a brick and stops. It starts about 2 bricks in from the corner and works its way up to the outside corner (so slightly diagnal). The adjacent connecting wall doesn't appear to be affected at all as it shows not signs of movement or cracks. I don't see any cracking up the wall. I wish I had a picture, but my camera is on the fritz. Any thoughts on this would be greatly appreciated.
-Segal
segal is offline   Reply With Quote
Old 03-06-2013, 08:59 PM   #2
Rewards Points: 13,296
Got a phone with a camera on it?
Sounds like normal settling but hard to say without a picture.
May need to use a 4-1/2" right angle grinder to remove 1/2 of morter and tuck point it. Any mason can do it if you do not want to.
I pore the morter into a masons bag (looks like a pastery bag)
Old 03-06-2013, 10:03 PM   #3
Rewards Points: 4,534
do you have a bsmt, slab, or crawl space ? think joe's right about possible settling however you may have a dropped foundation & need to place an underpinning under the fnd
Old 03-07-2013, 02:12 PM   #4
Rewards Points: 502
Are the bricks clay or concrete?
tony.g is offline   Reply With Quote
Old 03-07-2013, 02:51 PM   #5
joed's Avatar
Rewards Points: 12,002
Something moved. Bricks crack because of movement. Possible foundation issue.
Old 03-12-2013, 10:21 AM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,884
Pictures will help get you much more directed feedback as to the cause and effect.
One thing is true as pointed out above....it moved. Whether it is foundation settling, moisture, etc remains to be seen.
Attaching wood fence to house TheCowGod Building & Construction 5 04-13-2012 04:57 PM
crown molding fitting problem momof2labs Carpentry 16 10-15-2011 01:45 PM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 09:50 AM
Potential foundation issues oklahomaguy32 General DIY Discussions 7 02-14-2010 04:12 PM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 03:57 PM
