Brick Chimney Tuck Point Question - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-04-2014, 09:09 AM   #1
Rewards Points: 27
Our brick chimney at the top needs tuck point. Is it okay to do the work in the winter or is it better to wait for the temperature to rise a bit? Thank you.
Mikhail is offline   Reply With Quote
Old 02-04-2014, 10:38 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,384
Ayuh,.... I'd wait,... Mortar has to set up, not freeze up,....
The Following User Says Thank You to Bondo For This Useful Post:
Mikhail (02-04-2014)
Old 02-04-2014, 10:52 AM   #3
Rewards Points: 154
Professional masons have ways of doing it if it is really necessary, so you can call around and see how they handle it. If this is DIY and you aren't planning to drag a bunch of tarps and a heater up to your roof I would leave it til spring. You don't want freeze/thaw cycles to hurt your work before it sets up properly.
eharri3 is offline   Reply With Quote
The Following User Says Thank You to eharri3 For This Useful Post:
Old 02-04-2014, 12:44 PM   #4
Concrete & Masonry
Rewards Points: 582
Simply put, wait...............
jomama45 is online now   Reply With Quote
The Following 3 Users Say Thank You to jomama45 For This Useful Post:
concretemasonry (02-04-2014), Mikhail (02-04-2014), tony.g (02-07-2014)
Chimney construction question TTW Concrete, Stone & Masonry 1 03-09-2013 11:09 PM
Why a Chimney Liner? Rockford HVAC 0 07-12-2012 10:03 AM
Patching "holes" in exposed brick chimney CaptChaos Building & Construction 5 01-17-2012 03:09 PM
Insulation behind brick chimney? scoutn General DIY Discussions 13 11-15-2010 05:39 PM
Brick work to repair a Chimney worthspending Building & Construction 2 10-17-2010 07:58 AM
