Brick Chimney - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-10-2013, 09:11 PM   #1
Rewards Points: 240
brick chimney
mine has a clean out trap door, in the basement. i took the door off and it was full of dirt. i took a screwdriver and started digging it out. it seems this chimney is quite full. did they fill these back in the day ? or just decades of buildup ?
Fix'n it is offline   Reply With Quote
Old 03-11-2013, 12:02 PM   #2
Rewards Points: 1,232
That is where the ashes fall to. Clean it out and use it.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 03-11-2013, 09:16 PM   #3
Rewards Points: 240
as far as i know, and can tell. it has never been used for a fire place. though i am sure they had an oil burning furnace in here years ago.
i am figuring that all this dirt/junk was blown in there over the decades. probably because of bad chimney caps over the years.
Old 03-11-2013, 09:17 PM   #4
Rewards Points: 240
oh. it is in use = gas furnace and hwh.
water leaking through brick chimney quigleybmd Concrete, Stone & Masonry 45 02-26-2013 04:26 PM
How to install chimney liner Rockford How To Guides 3 07-16-2012 04:15 PM
old brick chimney repair DIherself Concrete, Stone & Masonry 8 03-20-2012 05:49 PM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 10:00 AM
Any good brick chimney water repellents? quigleybmd Roofing/Siding 3 04-12-2010 06:19 PM
