Brick Building - Water Damage - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-05-2013, 03:30 PM   #1
brick building - water damage
Hey - originally posted this in the Plaster section (http://www.diychatroom.com/f101/crum...-damage-189824) but this seems like it's more of a brick issue.
Got a church building built in 1931, brick exterior, plaster on the inside. Getting some really ugly damage from moisture that's getting through the brick. What I need to know is, how do we fix it? From what research I've done, it seems like the brick needs to allow the water vapor in and out, or it'll freeze and cause damage in the brick. But in heavy rains, we don't want the water seeping through and damaging the plaster on the inside. Bottom line is, I'm ignorant on this whole thing - how do we protect the brick and plaster at the same time?
Someone local recommended doing a water repellant treatment, which would last up to ten years. I'm wondering if that would fix the problem. People want to paint the interior and I'm holding them off because this issue needs to be fixed first. I'd hate to come up with the wrong solution
guruofgentoo is offline   Reply With Quote
Old 11-05-2013, 03:56 PM   #2
Rewards Points: 582
How thick is the brick wall? Also have you got a photo of the exterior.
stuart45 is offline   Reply With Quote
Old 11-05-2013, 06:42 PM   #3
Rewards Points: 3,628
Water repellant is the solution,whatever you do DO NOT SEAL IT,but it all depends on where your located,as it may be to late in the season to do it temperature wise.
Canarywood1 is online now   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
Old 11-06-2013, 06:35 AM   #4
Rewards Points: 4,656
you MAY have specific leak locations causing the water penetration & interior damage so repair them 1st ( brick replacement / repointing / flashing )
after that, suggest exterior cleaning followed by application of a waterproofing sealer ( silicone siloxane - prosoco or another reputable manufacturer ) [ no financial interest ]
Tags
brick , sealers , water damage
water leaking through brick chimney quigleybmd Concrete, Stone & Masonry 45 02-26-2013 04:26 PM
Help! Yellow Hot Water mechetti Plumbing 1 11-01-2012 08:57 PM
New Twist on Water Damage to Laminate Cruisecontrol Flooring 1 01-15-2011 02:52 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
