Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-06-2012, 12:31 AM   #1
Breaking out concrete to repair old shower drain pipes?
My old shower drainpipe is coming out of the slab crooked. In the old shower the drain assembly had been put on the pipe crooked and sealed with oakum to make it flush with the old shower floor.
I'm thinking about breaking out the concrete around the drain so I can replace the trap and make the pipe come up straight. I have a sledge hammer, but am concerned that the pipes might be damaged if I break the concrete that way. Is this true? I have a hammer drill, is there any way I could use that instead?
darsunt is offline   Reply With Quote
Old 11-06-2012, 04:49 AM   #2
Super Moderator
Your best bet is to rent a chipping hammer or a jack hammer----the best advice? Open it up enough to replace the P-trap----
There were two threads on that in the last week----
Old 11-07-2012, 10:59 AM   #3
Yes I will break it out enough to work on the P trap, and maybe to cut the pipe behind the p trap. I hope to join it to plastic with nohub. Then move the trap around to center the pipe coming up. Pipe position might become an issue depending on which shower pan method I decide on.
Also I plan to set the new pipes in gravel, and then put concrete the last 2 inches. Good plan?
I've looked briefly for those other threads. Can't find them...
Old 11-07-2012, 01:31 PM   #4
Super Moderator
Choosing The Right Shower Drain - Plumbing - DIY Home Improvement | DIYChatroom
This thread will help-------------
Old 11-07-2012, 08:39 PM   #5
Oh'mike, thanks a lot for the advice on getting a chipping hammer. There was not only concrete on top, but concrete wrapped around the pipe itself! Would have taken forever without the demolition hammer. The pipe looks okay, hope it wasn't damaged.
The Following User Says Thank You to darsunt For This Useful Post:
oh'mike (11-08-2012)
Tiled Shower Repair Help, Please Unicornz0 Plumbing 2 09-16-2012 10:22 PM
Shower Drain in Concrete Slab Install sharp21 Plumbing 4 08-30-2012 11:51 AM
AC Drain clogged - goes into concrete - no drain outlet at outside evap unit = ???? ReEstate-Rookie HVAC 4 08-27-2012 09:51 AM
Help with shower drain install in concrete floor!! psychomti Plumbing 0 05-17-2010 02:54 PM
Replacing shower drain in concrete floor rjgypsy Plumbing 1 11-30-2008 04:31 AM
