Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-11-2012, 07:58 PM   #1
Breaking concrete
An someone provide advice as to what is the best to use to break a concrete pad that is approx 4 inches thick?
Thank you!
mourad is offline   Reply With Quote
Old 09-11-2012, 08:27 PM   #2
bbo
Breaking concrete
free labor I vote for.
whats your budget? you could rent a cat, a jackhammer, use a sledgehammer.
bbo is offline   Reply With Quote
Old 09-11-2012, 09:10 PM   #3
Breaking concrete
I will hire a day laborer to do it. I am just wondering if a sledgehammer would work? If so, I will buy a sledgehammer, if it won't, I will rent a jack hammer.
Old 09-11-2012, 09:20 PM   #4
Breaking concrete
the jackhammer will be easier on your body then the sledge hammer will be and do it a lot faster.
Old 09-11-2012, 09:21 PM   #5
Breaking concrete
I use an abrasive saw and cut it up in sections then bust it up.
Then we scoop it up with a Skid loader and dump it into a dumpster.
Since you asking it's clear you have never done this before and have no idea what your in for.
Just trying to use a sluge hammer is never going to work out.
How big is this slab?
How do you plan on hauling it away?
Where do you plan on taking it?
Old 09-11-2012, 10:36 PM   #6
Breaking concrete
This wil give you an idea on just how much your going to be dealing with.
http://www.concretenetwork.com/concr...calculator.htm
Old 09-12-2012, 01:43 AM   #7
Breaking concrete
if it's a freestanding concrete pad, i would just use a jack hammer.
if it is poured next to the house foundation, i would also rent a small demolition hammer like Makita HM1214c
good luck
allthumbsdiy is offline   Reply With Quote
Old 09-12-2012, 08:43 AM   #8
No pain, no gain!
Breaking concrete
sorry wrong thread
paredown is offline   Reply With Quote
Old 09-12-2012, 04:17 PM   #9
Breaking concrete
rent an electric bosch brute breaking gun & 2" chisel bit from your local rental store - the apron/vest stores rent 40# guns which means harder work & longer rental periods - the 60# bosch still rules !
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Old 09-12-2012, 08:25 PM   #10
Breaking concrete
I rented that Bosch unit to crack open my basement floor to install a sump pump. It had awesome power, but everything in the house shook.
Few years later, I rented a small Makita to demolish my concrete patio step.
I went with Makita because I wanted a more controlled and accurate demolition to limit the transfer of any vibrations. You are right in that my demo project probably took about 4 hours longer than had I rented the Bosch unit.
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 12:19 PM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 02:20 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General Discussion 9 04-11-2010 07:11 AM
