-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Breaking concrete (http://www.diychatroom.com/f105/breaking-concrete-156553/)
mourad 09-11-2012 06:58 PM
Breaking concrete
An someone provide advice as to what is the best to use to break a concrete pad that is approx 4 inches thick?
Thank you!
bbo 09-11-2012 07:27 PM
free labor I vote for.
whats your budget? you could rent a cat, a jackhammer, use a sledgehammer.
mourad 09-11-2012 08:10 PM
I will hire a day laborer to do it. I am just wondering if a sledgehammer would work? If so, I will buy a sledgehammer, if it won't, I will rent a jack hammer.
DannyT 09-11-2012 08:20 PM
the jackhammer will be easier on your body then the sledge hammer will be and do it a lot faster.
joecaption 09-11-2012 08:21 PM
I use an abrasive saw and cut it up in sections then bust it up.
Then we scoop it up with a Skid loader and dump it into a dumpster.
Since you asking it's clear you have never done this before and have no idea what your in for.
Just trying to use a sluge hammer is never going to work out.
How big is this slab?
How do you plan on hauling it away?
Where do you plan on taking it?
joecaption 09-11-2012 09:36 PM
This wil give you an idea on just how much your going to be dealing with.
http://www.concretenetwork.com/concr...calculator.htm
allthumbsdiy 09-12-2012 12:43 AM
if it's a freestanding concrete pad, i would just use a jack hammer.
if it is poured next to the house foundation, i would also rent a small demolition hammer like Makita HM1214c
good luck
paredown 09-12-2012 07:43 AM
New Stoop and entrance slate
sorry wrong thread
stadry 09-12-2012 03:17 PM
rent an electric bosch brute breaking gun & 2" chisel bit from your local rental store - the apron/vest stores rent 40# guns which means harder work & longer rental periods - the 60# bosch still rules !
allthumbsdiy 09-12-2012 07:25 PM
I rented that Bosch unit to crack open my basement floor to install a sump pump. It had awesome power, but everything in the house shook.
Few years later, I rented a small Makita to demolish my concrete patio step.
I went with Makita because I wanted a more controlled and accurate demolition to limit the transfer of any vibrations. You are right in that my demo project probably took about 4 hours longer than had I rented the Bosch unit.
