Blue Stone Help Needed! Pics Inside - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-19-2012, 10:10 PM   #1
Blue Stone help needed! pics inside
well spent 10 hours chiseling out the old cement joints between these massive blue stones at my house today and had a couple questions for you guys
1) The sub floor these stones are on is almost a sandy/fine gravel cement mix of some sort and there is a weeping tile system around the patio But my question is will it be ok? i had ACL surgery a few months ago and the last thing i want to do is lift these monsters and pour a new slab
2) what Brand or kind of cement will hold up the longest? i picked up a few bags of some motor/cement mix but idk if its the rite one to use
Oh also do i need a expansion joint along the patio slab or just use tar paper?
any help would be great guys!!!! thanks again
Blue Stone help needed! pics inside-dsc00904.jpg   Blue Stone help needed! pics inside-dsc00906.jpg   Blue Stone help needed! pics inside-dsc00907.jpg   Blue Stone help needed! pics inside-dsc00909.jpg
629RWHPstang is offline   Reply With Quote
Old 06-19-2012, 10:27 PM   #2
bbo
id be tempted to pack some of that moss stuff between those joints ... you got some nice stones.
bbo is offline   Reply With Quote
Old 06-20-2012, 11:19 AM   #3
Rewards Points: 3,410
Sounds like the proper base is there,why not use polymeric sand insted of mortar,and no you don't need expansion joint or tarpaper.
Canarywood1 is offline   Reply With Quote
Old 06-20-2012, 05:29 PM   #4
gaps between the stone are to big for that no?
Old 06-20-2012, 06:30 PM   #5
Ravenworks's Avatar
Plant grass between the stones
U.S.M.C. "80-84" E.O.D. 1369
Ravenworks is offline   Reply With Quote
Old 06-20-2012, 06:34 PM   #6
HP2 will work.
http://www.techniseal.com/web/polymeric-sand.php?pl=13
Old 06-20-2012, 09:25 PM   #7
Nice stuff! so you would chose that over mortar?
Old 06-20-2012, 11:16 PM   #8
Concrete & Masonry
Rewards Points: 526
Both mortared joints or polymeric sanded joints will require some maintenance though the years, but the poly is far easier, and DIY friendly, to repair..........
The only way to ensure a long lifespan out of mortared joints is if the bluestone were to be wet-set over a rigid foundation, like a re-enforced concrete slab......
jomama45 is offline   Reply With Quote
Old 06-21-2012, 10:59 AM   #9
Absolutely,my motto is the less work the better!
Old 06-21-2012, 09:36 PM   #10
haha i like that well i picked up a bag of portland to mix myself to do the edges then ill decide if i want to use the sand like stuff or the pre mixed mortar
Old 06-21-2012, 09:40 PM   #11
Your call,good luck!
Old 09-09-2012, 09:52 PM   #12
After pics
Blue Stone help needed! pics inside-dsc00951.jpg   Blue Stone help needed! pics inside-dsc00955.jpg
Old 09-10-2012, 10:12 AM   #13
Looks great,i like the contrast.
Changing the color of stone misayo Interior Decorating 3 01-16-2012 03:59 PM
Another stone facing thread... paredown Building & Construction 0 12-06-2011 04:27 PM
blue color inside of wall switch TableTiger1 Electrical 5 08-05-2009 10:53 PM
Deck - 45 spindles - advice wanted (pics inside) Kevin K Building & Construction 21 06-06-2007 11:28 AM
This is bad, right? (pics inside) dalesd Roofing/Siding 8 02-16-2006 09:33 PM
