-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Blue Stone help needed! pics inside (http://www.diychatroom.com/f105/blue-stone-help-needed-pics-inside-147633/)
629RWHPstang 06-19-2012 09:10 PM
4 Attachment(s)
well spent 10 hours chiseling out the old cement joints between these massive blue stones at my house today and had a couple questions for you guys
1) The sub floor these stones are on is almost a sandy/fine gravel cement mix of some sort and there is a weeping tile system around the patio But my question is will it be ok? i had ACL surgery a few months ago and the last thing i want to do is lift these monsters and pour a new slab
2) what Brand or kind of cement will hold up the longest? i picked up a few bags of some motor/cement mix but idk if its the rite one to use
Oh also do i need a expansion joint along the patio slab or just use tar paper?
any help would be great guys!!!! thanks again:thumbsup:
bbo 06-19-2012 09:27 PM
id be tempted to pack some of that moss stuff between those joints ... you got some nice stones.
Canarywood1 06-20-2012 10:19 AM
Sounds like the proper base is there,why not use polymeric sand insted of mortar,and no you don't need expansion joint or tarpaper.
629RWHPstang 06-20-2012 04:29 PM
gaps between the stone are to big for that no?
Ravenworks 06-20-2012 05:30 PM
Plant grass between the stones
Canarywood1 06-20-2012 05:34 PM
HP2 will work.
http://www.techniseal.com/web/polymeric-sand.php?pl=13
629RWHPstang 06-20-2012 08:25 PM
Originally Posted by Canarywood1 (Post 947866)
Nice stuff! so you would chose that over mortar?
jomama45 06-20-2012 10:16 PM
Both mortared joints or polymeric sanded joints will require some maintenance though the years, but the poly is far easier, and DIY friendly, to repair..........
The only way to ensure a long lifespan out of mortared joints is if the bluestone were to be wet-set over a rigid foundation, like a re-enforced concrete slab......
Canarywood1 06-21-2012 09:59 AM
Absolutely,my motto is the less work the better!
629RWHPstang 06-21-2012 08:36 PM
haha i like that:thumbup: well i picked up a bag of portland to mix myself to do the edges then ill decide if i want to use the sand like stuff or the pre mixed mortar
Canarywood1 06-21-2012 08:40 PM
Your call,good luck!
629RWHPstang 09-09-2012 08:52 PM
2 Attachment(s)
After pics:thumbup:
Canarywood1 09-10-2012 09:12 AM
Looks great,i like the contrast.
