Blown Out Block Face Repair - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-11-2014, 09:16 PM   #1
Jack of all trades
Superintendent's Avatar
Blown out block face repair
Hello fellow DIYers. Came across a repair I have not done before. Looking for anyone with experience with this situation. I am working on a site where the block face has blown out or has severely deteriorated on a commercial store. I am including photos for reference. I am wondering if anyone has a suggested repair procedure and material they prefer to use in this situation. I would use just a mortar mix and a standard bonding glue if it was in a different location, but this is in a higher wall and I am worried about failure and possible injuries if it fails. Therefore price is not an object, but something reasonable is always good if it is safe. I am thinking an epoxy type repair would be the best but looking for someone with some expertise to guide me to the correct procedure and material. See attached pic.
If anyone has the knowledge and expertise, would appreciate some help.
Superintendent is offline   Reply With Quote
Old 06-15-2014, 03:55 AM   #2
Rewards Points: 4,578
you'll find vertical & overhead repair mortars @ any const supply house,,, we'd probably chip down to good, anchor some expanded s/s wire mesh, then lay on the repr mortar,,, you can color the mix wtr w/pigments from sher-wms,,, always start light 'cause you can't go light IF you begin too dark,,, the key is polymer-modified - epoxies are not exterior useable NOR uv resistant,,, polyureas & polyaspartics are but they're VERY tricky
what you're looking for is something like ' cathedral ' stone repr mortar however you can't buy that as its proprietary to licensed artisans,,, just ask for vert repr stuff - just like in a tunnel - good luck !
sorry i miss'd this - irc
The Following 2 Users Say Thank You to stadry For This Useful Post:
de-nagorg (06-15-2014), Superintendent (06-16-2014)
Old 06-16-2014, 09:59 AM   #3
Jack of all trades
Thanks for the info, I went with a quickset mortar while using a bonding agent. One base coat to fill the large voids then a final coat to get me close to the finish surface. When chipping out the bad block, I found that the surface was an actual tile only an 1/8" thick. So I finished the application with a VCT applied with a structural adhesive and then applied a caulking to replicate the mortar joints. Will apply a primer then apply our finish paint coat.
Last edited by Superintendent; 06-16-2014 at 10:11 AM. Reason: Trying to apply photo of finish
Old 06-16-2014, 10:19 AM   #4
Jack of all trades
Here is a pic of the completed work prior to primer-
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 06:42 AM
Rebuilding a cinder block wall Pawl Building & Construction 5 10-09-2011 09:46 PM
How to repair cement block walls hc1974 Building & Construction 2 08-20-2011 07:30 PM
Vertical Rebar Layout in Block Wall Footing 99altrade Building & Construction 6 08-12-2011 09:32 PM
Concrete block repair hitmehhh Building & Construction 5 03-07-2009 09:43 PM
