Block Paving Manhole Inspection Cover - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-04-2012, 09:38 AM   #1
Block paving manhole inspection cover
I have a square manhole cover on my blockpaved drive.Its getting too heavy for me to lift so I would like to replace this with a round pvc inspection cover and at the same time reduce the riser outlet to a diameter to match the new pvc cover. The existing riser is 470mm. Is there a way of going from a 470mm riser to a smaller diameter riser without replacing the whole of the 470mm riser.?
Mike N is offline   Reply With Quote
Insulate Top of Cinder block wall HooKooDooKu Building & Construction 0 01-20-2010 11:58 PM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 03:53 AM
Central Air Outside Unit Cover czars HVAC 2 01-07-2009 11:23 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 08:34 PM
What do I cover the outside basement block with? kleinma Building & Construction 9 10-12-2007 10:51 PM
