Block To Floor Seal - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-21-2014, 12:27 PM   #1
Block to floor seal
Hello all new here, I have a question. I new to tear down a old block 12x12 under ground somewhat and lay block on top of concrete floor 5x5 just to house water system with holding tank. I am going to drill and put re-bar in floor and wire between the blocks with a hinged roof for access . What would be the best way to get a good seal to the floor. Thanks Steve
boondocker is offline   Reply With Quote
Old 05-21-2014, 01:20 PM   #2
Rewards Points: 732
Mortar should work fine.
But if you want it stuck permanent and sealed very well use P L construction adhesive. That stuff sticks almost everything together.
ED
de-nagorg is offline   Reply With Quote
Old 05-26-2014, 08:06 AM   #3
Thanks for the info, Steve
The Following User Says Thank You to boondocker For This Useful Post:
de-nagorg (05-26-2014)
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 01:26 PM
Concrete (Cinder) Block Barebones Home : Seeking Advice granadaCoder Building & Construction 11 08-11-2012 08:03 AM
Vertical Rebar Layout in Block Wall Footing 99altrade Building & Construction 6 08-12-2011 10:32 PM
Vinyl Window in Concrete Block Wrongwrench Carpentry 4 12-07-2010 11:21 AM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-06-2009 12:02 AM
