Black Holes On Surface Of New Patio - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-30-2013, 11:32 AM   #1
Black Holes on surface of new patio
Had a concrete with integral color patio poured on Saturday. On Monday morning we noticed small (1/8" - 1/4") black holes with oiling substance in middle. They are at the surface and and when the oily substance is removed the depth is about an 1'8" deep with a light brown ring around the hole and the black stuff feels gritty. The cement company said it was the sand base and the concrete company the we hired to install the patio said that it was something in the mixture or inside the truck was contaminated. Any ideas anyone, we need some help!!
Grits is offline   Reply With Quote
Old 04-30-2013, 03:13 PM   #2
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
Is it a shade of black? I wonder if the contractor had the driver add a powdered color on site (instead of at the plant, like you're supposed to), and it didn't mix for long enough.
I hate signatures.
Mort is online now   Reply With Quote
Old 04-30-2013, 03:31 PM   #3
Black holes on surface of new patio
It was mixed on site! But the color added is a light brown
Old 04-30-2013, 05:18 PM   #4
Rewards Points: 3,364
Best thing to do is collect a sample and take it to a lab to have it analyzed,it's the only way to find out what's really going on,and i have never heard of a sand base rising to the surface overnight.
Canarywood1 is offline   Reply With Quote
Old 04-30-2013, 05:27 PM   #5
Mort's Avatar
Rewards Points: 690
The color powder is always darker than the finished product, because it lightens as the concrete cures.
The truck needs to have a bit of water added and the drum spun all the way up for 5-10 minutes for that stuff to mix in properly. I wonder if it didn't, and some pockets of color powder remained.
I hate signatures.
Old 05-01-2013, 11:01 AM   #6
Black holes on Patio
Thank you so much for your reply. Since yesterday the entire surface of the 18' x 18' patio is covered with these holes and something that looks like a larvae size about 1.5" in length. I swear!! I will try to attach pictures.
Black Holes on surface of new patio-img_0482.jpg   Black Holes on surface of new patio-img_0485.jpg   Black Holes on surface of new patio-img_0484.jpg
Old 05-01-2013, 11:20 AM   #7
I will contact the parish (county) extension service for help.
Old 05-01-2013, 12:00 PM   #8
What about rust from that metal mesh that was between sand and concrete coming to surface?
Old 05-01-2013, 02:39 PM   #9
Rewards Points: 4,454
think mort's on the right path - not enough mixing time, wet powder rather than liquid color, contaminated drum, OR dirty stockpiles,,, the other pic shows why 1 should NEVER allow the driver to spit his chewing tobaccy into the drum either way get the conc co's rep out to look at it
doubt its rust from mesh
The Following User Says Thank You to stadry For This Useful Post:
Grits (05-01-2013)
Old 05-01-2013, 02:47 PM   #10
The concrete company's rep did come out to the house and said that it was not the cement mixture but "bad sand". Whatever that means. I think we will have a fight on our hads in the next few days. But it is going to be fixed! The patio installer pressure washed it and told us that he would apply a color stained sealer that would fix it. I am beginning not to believe him. But he has not been able to apply it since it rained yesterday. Now we have hundreds of holes on the 18' x 18' patio.
Old 05-01-2013, 03:00 PM   #11
cement is an ingredient as is sand ( fine aggregate ),,, a color'd sealer will NOT seal the holes IF they're as large as you described,,, if someone's pees on your leg & sez its raining, what does that tell you ' bad sand ' = bad concrete
Old 05-01-2013, 03:06 PM   #12
Makes sense to me. The company rep probably thinks we are dumb and can tell us BS and we will believe him. It is time to pay the company a personal visit.
Old 05-01-2013, 03:24 PM   #13
JOATMON
ddawg16's Avatar
Rewards Points: 828
Grits...that first pic looks like what is left of something that 'was' alive at one point.....you might want to start scanning for missing persons in the news. If someone is missing....call the police....you found 'part' of him.
ddawg16 is online now   Reply With Quote
Old 05-01-2013, 03:30 PM   #14
Funny! It does look like the thing has an arm and maybe tail. What started out as a great home improvement has turned into a horror story. The black spots are the worse but this "thing" is over the top.
Old 05-01-2013, 04:03 PM   #15
I doubt an extension service is going to help,you need a concrete testing lab,because they are going to throw a ton of BS at you,both the contractor and supplier.
New Patio Roof Construction ryanb4614 Building & Construction 7 07-16-2012 06:53 AM
Two black wires and two white wires in a ceiling mshaw11 Electrical 6 07-11-2012 10:57 PM
Patio Door Question Smitty1 Building & Construction 8 09-01-2011 06:29 PM
Making a uniform patio surface emnolan29 Flooring 0 07-02-2011 01:05 PM
Patio Cracked & Sinking silvabul Building & Construction 3 05-04-2011 10:53 AM
