-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Black Holes on surface of new patio (http://www.diychatroom.com/f105/black-holes-surface-new-patio-178447/)
Grits 04-30-2013 10:32 AM
Had a concrete with integral color patio poured on Saturday. On Monday morning we noticed small (1/8" - 1/4") black holes with oiling substance in middle. They are at the surface and and when the oily substance is removed the depth is about an 1'8" deep with a light brown ring around the hole and the black stuff feels gritty. The cement company said it was the sand base and the concrete company the we hired to install the patio said that it was something in the mixture or inside the truck was contaminated. Any ideas anyone, we need some help!!
Mort 04-30-2013 02:13 PM
Is it a shade of black? I wonder if the contractor had the driver add a powdered color on site (instead of at the plant, like you're supposed to), and it didn't mix for long enough.
Grits 04-30-2013 02:31 PM
Black holes on surface of new patio
It was mixed on site! But the color added is a light brown
Canarywood1 04-30-2013 04:18 PM
Best thing to do is collect a sample and take it to a lab to have it analyzed,it's the only way to find out what's really going on,and i have never heard of a sand base rising to the surface overnight.
Mort 04-30-2013 04:27 PM
The color powder is always darker than the finished product, because it lightens as the concrete cures.
The truck needs to have a bit of water added and the drum spun all the way up for 5-10 minutes for that stuff to mix in properly. I wonder if it didn't, and some pockets of color powder remained.
Grits 05-01-2013 10:01 AM
Black holes on Patio
3 Attachment(s)
Thank you so much for your reply. Since yesterday the entire surface of the 18' x 18' patio is covered with these holes and something that looks like a larvae size about 1.5" in length. I swear!! I will try to attach pictures.
Grits 05-01-2013 10:20 AM
I will contact the parish (county) extension service for help.
Grits 05-01-2013 11:00 AM
What about rust from that metal mesh that was between sand and concrete coming to surface?
stadry 05-01-2013 01:39 PM
think mort's on the right path - not enough mixing time, wet powder rather than liquid color, contaminated drum, OR dirty stockpiles,,, the other pic shows why 1 should NEVER allow the driver to spit his chewing tobaccy into the drum :eek: either way get the conc co's rep out to look at it :yes:
doubt its rust from mesh
Grits 05-01-2013 01:47 PM
The concrete company's rep did come out to the house and said that it was not the cement mixture but "bad sand". Whatever that means. I think we will have a fight on our hads in the next few days. But it is going to be fixed! The patio installer pressure washed it and told us that he would apply a color stained sealer that would fix it. I am beginning not to believe him. But he has not been able to apply it since it rained yesterday. Now we have hundreds of holes on the 18' x 18' patio.
stadry 05-01-2013 02:00 PM
cement is an ingredient as is sand ( fine aggregate ),,, a color'd sealer will NOT seal the holes IF they're as large as you described,,, if someone's pees on your leg & sez its raining, what does that tell you :eek: ' bad sand ' = bad concrete
Grits 05-01-2013 02:06 PM
Makes sense to me. The company rep probably thinks we are dumb and can tell us BS and we will believe him. It is time to pay the company a personal visit.
ddawg16 05-01-2013 02:24 PM
Grits...that first pic looks like what is left of something that 'was' alive at one point.....you might want to start scanning for missing persons in the news. If someone is missing....call the police....you found 'part' of him.
Grits 05-01-2013 02:30 PM
Funny! It does look like the thing has an arm and maybe tail. What started out as a great home improvement has turned into a horror story. The black spots are the worse but this "thing" is over the top.
Canarywood1 05-01-2013 03:03 PM
I doubt an extension service is going to help,you need a concrete testing lab,because they are going to throw a ton of BS at you,both the contractor and supplier.
