Black Basement Conder Blocks - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-15-2014, 05:02 PM   #1
Rewards Points: 53
I was removing some old paneling-on-1x2 walls as part of a project to do some proper finishing - the cinder blocks are black. Does anyone recognize this? Some sort of attempt at a waterproofing sealant?
corsulian is offline   Reply With Quote
Old 06-15-2014, 05:14 PM   #2
Rewards Points: 4,454
doubt they're black but, rather, there's a black coating on them,,, was it leaking at 1 time or don't you know ? looks like a misguided feeble attempt @ ' waterproofing ' diy-style to me
irc
Old 06-15-2014, 05:23 PM   #3
Rewards Points: 12,854
Hard to tell from that picture.
Sure it's not just felt paper? Just looking at the white vertical lines.
What's all the black on the baseboards?
Is this below grade?
Old 06-15-2014, 05:25 PM   #4
Rewards Points: 53
Originally Posted by itsreallyconc
doubt they're black but, rather, there's a black coating on them,,, was it leaking at 1 time or don't you know ? looks like a misguided feeble attempt @ ' waterproofing ' diy-style to me irc
Yep. The pipe on the right is part of our heavy duty water mitigation - before that, there's evidence that this room saw a lot of flooding. Thanks.
Old 06-15-2014, 05:29 PM   #5
Is that also plywood on the floor as a subfloor?
Old 06-15-2014, 06:01 PM   #6
Rewards Points: 53
Originally Posted by joecaption
Hard to tell from that picture. Sure it's not just felt paper? Just looking at the white vertical lines. What's all the black on the baseboards? Is this below grade?
I gave it a little scrape and it didn't want to come off - guessing it's a sealant from 20-25yrs ago. It is below grade - the black on baseboards is just dirt - our hydronic heat was decommissioned so I'm removing those - every pipe has at least a little standing black water. Real nice.
Old 06-15-2014, 06:02 PM   #7
Rewards Points: 53
That's just my mess from removing the panel section - I just wanted to see what I was dealing with there. The floor is a lovely concrete with mastic-adhered 9x9 tiles.
Options for new basement Perry401 Building & Construction 8 02-27-2013 10:22 PM
Double switch wiring rockclimber Electrical 18 03-18-2012 11:13 PM
basement flooring suggestions? jeffro83 Flooring 2 05-14-2011 01:58 PM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 08:46 PM
Baseboards with Logix blocks for basement ReluctantFarmer Building & Construction 1 07-22-2008 10:57 AM
