Big Chipped Brick Easy Quick Fix - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-14-2012, 09:10 AM   #1
Rewards Points: 190
I was drilling from inside out on my brick house to run a water line out for the front. I couldn't get through the brick so I got my hammer drill and got through. Went outside to check on everything and it chipped the entire face of the brick. I did not go from the outside in because I wasn't sure where it would come in ( coming from basement). So my question is what can I do with this brick to make it more even to redo the face of the brick where the faucet is going to be mounted. I now don't even have a flat surface to mount the faucet now...
ryanb4614 is offline   Reply With Quote
Old 04-14-2012, 10:15 AM   #2
joed's Avatar
Rewards Points: 11,966
It is possible to cut the mortar out out and replace one brick IF you have a matching one to put back in.
Old 04-14-2012, 12:09 PM   #3
Ravenworks's Avatar
Or you could mount a piece of wood where the corners don't come to a 90 but are concave then round over the edges and paint,would look good and be a nice work around.
I had to do this when a cable installer blew out one of my glazed tile block,after I told him not to drill on my block.
Ravenworks is offline   Reply With Quote
Old 04-14-2012, 12:13 PM   #4
Rewards Points: 13,250
I use a piece of 1 X 6 vinyl lumber instead of wood. Never going to rot or have peeling paint I have to deal with later.
Old 04-14-2012, 02:57 PM   #5
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Use concrete patch and color it.
http://www.acehardware.com/product/i...d=55448111794U
*Stuff the hole from the outside with paper
*Mix a little cement with some red food coloring
*Apply and smooth out the patch
*Wait an hour, if you are happy with the color then redrill the hole from the inside
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-14-2012, 03:42 PM   #6
Too Short? Cut it Again!
Abatron has epoxy based wood, masonry and concrete restoration products that are pricey but very good. You can color them and tool them easily. They can even be painted and stained (to a point). They will bond well with the existing material and be as strong.
Old 04-16-2012, 11:11 AM   #7
Rewards Points: 190
Thank you for the suggestions bought red dye and cement. Will keep posted.
Old 04-16-2012, 02:20 PM   #8
Tool Geek
PaliBob's Avatar
Thanks for the feedback.
Let us know how it turnss out.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-24-2012, 08:49 AM   #9
Rewards Points: 152
I like the vinyl wood idea. Easy, inexpensive and will last forever.
TRUEPRO is offline   Reply With Quote
Expansion / Contraction 2x4 whitewood studs on brick bpardo Building & Construction 2 08-29-2011 03:22 PM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 06:45 PM
Run wire to Breezeway through brick and up brick wall wad2k Electrical 0 04-16-2010 09:18 AM
Potential foundation issues oklahomaguy32 General DIY Discussions 7 02-14-2010 04:12 PM
Quick and easy hychesee Building & Construction 1 02-09-2009 07:33 AM
