Best Way To Fill Big Hole In Foundation - Concrete, Stone & Masonry - Page 3 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-01-2013, 01:56 PM   #31
Concrete & Masonry
Rewards Points: 530
Personally, I wouldn't be using a NS grout for what you're trying to accomplish. There's really no need for a 10-12K psi mix. Not to mention, that stuff is self-leveling and will put more load on your formwork. Standard 4000 psi "quickcrete" mixed relatively wet and poured into the top of the form will suffice. I'd also add a few dowels into the existing just to keep it from potentially "creeping" ahead through time. For pour like this with no access from the top, we'll either remove some concrete at the top to allow the concrete to be poured in, or drill a 4.5" hole into the very top of the forms and attach a 4" PVC street elbow to pour the concrete into and allow for head pressure to ensure it's full..............
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
noquacks (03-01-2013)
Old 03-01-2013, 03:02 PM   #32
Rewards Points: 1,062
And once its full, you leave the elbow partly full of mix, to harden? Then, after removing form, does that excess which hardened into elbow just snap off?
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 03-01-2013, 03:32 PM   #33
Concrete & Masonry
Rewards Points: 530
We typically wait a little while for the concrete to become firm and pull the elbow and replace it with the piece of lumber/plywood we drilled out with a hole saw..........
Exterior foundation and veneer cracks - fill it in? n0chance Building & Construction 0 04-16-2012 08:30 PM
Huge hole in foundation texasgolfer Building & Construction 2 01-07-2011 06:55 PM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 10:26 AM
Larger hole in foundation jamiedolan Building & Construction 5 10-02-2008 12:04 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
