Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-24-2013, 01:03 PM   #1
Best way to fill big hole in foundation
Guys,
have a garage which is walk out- back part of it is entirely underground (its against a hill). Previous owners cut a 3x3' hole in the back of the garage into this foundation. It gave them an extra 2' or so so they could store their dumb boat entirely inside. Sheesh.
Now, I wish to repair . The thickness is about 10". It shows rebar cut- 2 vertical, and one horizontal. Do I need to replace rebar (drill, slide in), or can I makie a form and pour 5000 psi concrete without rebar? (will try to post a picture soon....)
Thanks!
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 02-24-2013, 01:09 PM   #2
How lucky are you.
Look up Core Drilling or Concrete cutting in the phone book.
It's a long shot but they may be able to set you up with plug that they have removed or know where there's one laying around.
I'd be using hydrolic cemet not concrete if you can not find a plug.
Hydrolic will expand and lock in place better.
noquacks (02-24-2013)
Old 02-24-2013, 01:10 PM   #3
picture of the hole attached -
Old 02-24-2013, 01:22 PM   #4
I was picturing a round hole.
Best way would be to remove some of the blocks left in place so there would be a running bond to lock the new ones in place.
Old 02-24-2013, 01:34 PM   #5
OK, thanks, Joe, but theres no blocks- its not a cement block foundation, its poured. But I like the idea of hydrolic cement. I can mix/pour that and use no rebar?? HD sell it?
Old 02-24-2013, 01:36 PM   #6
Also, was hoping to be able to pour in multiple pourings, so less weight per pour. Say, if I didnt have the plywood held in tightly enough, and the whole slurry mess falls out all at once!!! Can I pour it say, in 3 pourings (where I would be dealing with a limited mix/slurry, say, only a foot high?)
Old 02-24-2013, 03:28 PM   #7
hang a picture over it.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 02-24-2013, 04:20 PM   #8
funfool's Avatar
just my thought, I would put some rebar in it, try to tie it back into the original foundation.
Just drill 6-8" into the concrete. maybe 2 on top, bottom, left and right.
Would be 8 holes and 8 pieces of bar using tie wire to connect.
Maybe someone else can add to the rebar idea, but at very least I would do that.
Will be interesting on how you form that and pour in the cement. probably will want to chip out some sort of access hole on top, attach a piece of plywood to the wall and pour concrete through the access hole you created.
The problem will be the weight as you suggest, will not be able to fasten the plywood to the wall strong enough to hold while it sets up.
Do you have a 4x4 pickup with the bumper at the right hight? Mount the plywood to the wall, then back the truck up into the plywood to hold it in place, can stand in the bed and pour the concrete in?
If it was easy, we would not call it work!
funfool is offline   Reply With Quote
The Following User Says Thank You to funfool For This Useful Post:
Old 02-24-2013, 04:31 PM   #9
These are some solid (pun?) idea! Yes, you get what Im talking about regarding all the weight pushing "back" out, ifn one pours ALL the slurry at once. All I have is a small car. But Im gonna figure it out. Need lots of weight against the plywood .......3 pours could do it.
yes, could drill and tie in rebar somehow.
Old 02-24-2013, 04:47 PM   #10
funfool's Avatar
Go to home depot and rent a bulldog, will need it to drill the holes for the rebar, and also want a chipping bit to make the access hole to pour the concrete in, and again to install fasteners to bolt the plywood to the wall. You really are going to want a hammer drill for this project.
But holding the plywood form is going to be a creative process.
noquacks (02-25-2013)
Old 02-25-2013, 12:37 AM   #11
Agree it's awkward, but what problem is the hole causing?
____________
Vince
Old 02-25-2013, 03:21 PM   #12
Right now, no problem. Maybe I could/should live with it? Also, say I want to sell the house- it would be a bad selling point.
Old 02-25-2013, 04:57 PM   #13
All you need to do with that is fill it with grout in 2 lifts,and your good to go,no steel required,just keep the grout on the stiff side.
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
Old 02-25-2013, 05:37 PM   #14
really? Grout? Like tile grout for ceramic tiles? No rebar? Is that cuz tile grout is soooo strong? Man if that works, Im all for it!
Old 02-25-2013, 06:16 PM   #15
Concrete grout,a sand and cement mix,and when you get it poured tap the form board a half dozen times to ensure a nice smooth finish when you remove the board.
Exterior foundation and veneer cracks - fill it in? n0chance Building & Construction 0 04-16-2012 08:30 PM
Huge hole in foundation texasgolfer Building & Construction 2 01-07-2011 06:55 PM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 10:26 AM
Larger hole in foundation jamiedolan Building & Construction 5 10-02-2008 12:04 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
