Best Pre-Mix Mortar For Veneer Stone - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-06-2013, 02:03 PM   #1
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
Best Pre-Mix Mortar for Veneer Stone
I was at HD the other day shopping for materials for an exterior stone veneer project. I provide the materials and a friend of the family will do the masonry work. In the aisle with mortar mixes, I saw Quickcrete Mortar Mix and the label on the rack said it was for veneer stone. I asked the guy working in the aisle and he confirmed that was the right stuff. So I bought 6 bags.
Yesterday I'm looking at a Quickcrete video and they suggest "Veneer Stone Polymer Modified" mortar saying it had better holding properties. FWIW, the stone will be installed over plywood with paper and 2.5# mesh over that, on either side of the garage door, in a column fashion.
Should I take the mortar mix back and try to find the polymer modified mortar? HD doesn't carry it.
JulieMor is offline   Reply With Quote
Old 09-06-2013, 04:50 PM   #2
Not so new
12penny's Avatar
Rewards Points: 520
Have you checked the veneer manufacturers website for
their recommendation?
12penny is offline   Reply With Quote
The Following User Says Thank You to 12penny For This Useful Post:
GBrackins (09-06-2013)
Old 09-07-2013, 05:28 AM   #3
Rewards Points: 4,578
just my ns-h-fo but neither the apron OR vest store carry bldg mtls that require knowledgeable sales personnel,,, look for a const supply house for that material,,, polymer-mod'd mtls are MUCH better - flexibility, tension, compressive, & holding strength
The Following User Says Thank You to stadry For This Useful Post:
JulieMor (09-07-2013)
Old 09-07-2013, 07:12 AM   #4
JulieMor's Avatar
Rewards Points: 518
The manufacturer says to use the pre-mix mortar or an S mortar & sand mixed on site. They said you CAN use a bonding agent but don't require it.
I've been looking for a specialty store in the area. The one I used to go to is gone. I'll keep checking.
Quickcrete claims their polymer modified stone veneer mortar has twice the holding strength of their regular mortar. All I have to do is find it!
Old 09-07-2013, 08:07 AM   #5
Concrete & Masonry
Rewards Points: 548
Just buy a gallon of bonding admixture and put a few ounces into each batch/bag. You'll end up with the same result.......
jomama45 is offline   Reply With Quote
Best mortar mix for stone veneer heinlein0311 Concrete, Stone & Masonry 10 03-29-2012 07:00 AM
Field Stone and Mortar Wall, will it be stable? NorskeDiv Landscaping & Lawn Care 4 07-14-2011 10:18 AM
Stone foundation in barn - add lime or mortar? tbeaulieu Building & Construction 0 06-18-2011 03:28 AM
Stone wall problem with mortar weberus3 Building & Construction 22 01-06-2010 08:06 AM
