Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-12-2011, 09:36 AM   #1
best mortar for repointing a chimney
what is the best mortar to repoint a brick chimney with? can i use FSB fiberglass bonding cement? ive heard if you use the wrong stuff the bricks can crack because of expansion/ contraction. any reccomendations would be helpful, thanks. also i have raked joints on the exterior but theyre not falling apart yet. only a few small holes and gaps. can i just put the mortar right over the old stuff or do i have to scrape it out first?
jared123 is offline   Reply With Quote
Old 12-12-2011, 10:38 AM   #2
Tileguy
Bud Cline's Avatar
You should remove 1/3 to 1/2 the depth of the whole joint. Tuck it with brick mortar. Press it in tight.
Old 12-12-2011, 12:13 PM   #3
In most cases when repointing, you want to use a mortar that has similar properties to the original mortar. THis is mostly an issue with historic brickwork. And they say that if you really have to work to rake out the old mortar, then you are better off leaving it alone.
Windows is offline   Reply With Quote
Old 06-28-2012, 07:37 PM   #4
Sorry I may be in the wrong place here but anyway I need help with the right mortar mix. I am re-pointing 100 year old brick have type N mortar and mason sand but keep seeing lime should be added I don't have it will I be ok?
Linn is offline   Reply With Quote
Old 06-28-2012, 09:24 PM   #5
Super Moderator
Linn---Please start a new thread---you will get the best attention that way---Mike---
Old 12-19-2012, 09:08 AM   #6
Hi Linn,
Be sure to find out what the makeup of your mortar is before you begin repointing. For a home that is 100 years old it will most likely have been built with a lime mortar containing no harmful Portland Cement. Your brick may be too soft for any mortar mix that contains Portland Cement. Get in touch if you have further questions.
Sean
smax21 is offline   Reply With Quote
More Stone Foundation Repair PAVenturer Building & Construction 11 09-18-2011 08:44 AM
mortar for repairing chimney kelley4180 Building & Construction 8 03-15-2010 11:09 AM
Chimney repair: rebuild or repoint? cloud9 Building & Construction 33 09-22-2009 10:12 PM
Painting exterior brick with latex? hellothere123 Painting 10 09-19-2008 09:50 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing 6 03-07-2008 04:12 PM
