Best Material To Patch Crack In Exterior Concrete Window Sill? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-29-2014, 10:55 AM   #1
Rav
Rewards Points: 564
Best material to patch crack in exterior concrete window sill?
I have an exterior concrete window sill that has a crack in it that I want to patch (pic attached). What would be an appropriate material to fill it with? I have on hand a tube of Big Stretch caulk, and a tub of DAP Bondex ready-mixed concrete patch. Would either of those work well? Or should I get something such as Quikrete crack sealant concrete repair (caulk), or GE Silicone II Concrete & Masonry Caulk, or ...? My prep plan is to wire brush and then blow out with a can of compressed air. Thanks. / Rav
Rav is offline   Reply With Quote
Old 03-29-2014, 11:26 AM   #2
Rewards Points: 13,960
Anything you try to fill it with is going to stick out like a sore thumb and not going to fix it.
Old 03-29-2014, 12:18 PM   #3
Rav
Rewards Points: 564
What would you do then, Joe? I would have tried filling it with something that would match the color as well as possible. Wouldn't it be better to fill it with an appropriate material than to allow water to continue to get in there and make it worse by expanding and contracting?
Old 03-29-2014, 01:06 PM   #4
Jmayspaint's Avatar
Rewards Points: 534
This stuff holds pretty well on masonry. It's made to match mortar more so than concrete, but would still match better than Big Stretch.
http://www.sashco.com/products/mor-flexx/
Yeah, I would clean it and fill it.
Jmayspaint is offline   Reply With Quote
The Following User Says Thank You to Jmayspaint For This Useful Post:
Rav (03-29-2014)
Old 03-29-2014, 02:39 PM   #5
Rewards Points: 3,718
You need a permanent fix, not something you have to do once a year, here's a link.
Forgot to say watch the video.
http://www.mudsupply.com/Simpson-Str...FU4R7AoddTQASA
Canarywood1 is offline   Reply With Quote
Window Sill The Beam Carpentry 11 10-23-2011 03:55 PM
Moisture on drywall and window sill redwings83 General DIY Discussions 4 09-26-2011 04:11 PM
Window sill recess 4 a brick wall RedBear Building & Construction 0 07-17-2011 09:53 PM
Shower Window Sill cnick Kitchen & Bath Remodeling 3 11-26-2010 09:00 PM
Window jamb helpless handyman Carpentry 11 08-03-2006 12:45 PM
