Best Drill Bit For Old Concrete - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-12-2012, 02:41 PM   #16
Thanks PaliBob,
initially depth was a problem, but a new longer bit took care of that. I think it might be a "cleaning" problem. I am using a shop vac to get the dust out, I might just need to work a bit harder on it.
The shop vac might just be pulling dust up the hole, and not all the way out. I will something thinner, and push it down the hole to make sure it is clear.
Thanks again,
Jack
Originally Posted by PaliBob View Post
Ultracon screws are almost the same as the more commonly known Tapcons but they have an impressive history.
http://www.tannerbolt.com/default.as...-ultra-con.htm
It sounds to me that you are not drilling the holes deep enough, or the holes are not being cleaned enough.
From the TapCon Site: Ref http://www.concretescrews.com/tapcon-questions.aspx
johnjack11 is offline   Reply With Quote
Old 03-12-2012, 03:31 PM   #17
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by johnjack11 View Post
....I think it might be a "cleaning" problem....
Make a depth gauge with an unsharpened pencil with a blue masking tape marker to indicate hole depth.
Any powder residue should show up on the depth gauge.
Another thing you can do is use a small diameter funnel taped to the end of the vacuum hose.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-12-2012, 07:21 PM   #18
Funnel is a great idea.
I picked up the Chicago rotary hammer tonight, will give it a try tomorrow. Too late now and the kids are in bed.
I was hoping to find an sds driver bit to drive the ultracons too, but did not see one at lowes or online.
Has anyone seen another manufacturer that makes these:
http://www.toolstop.co.uk/makita-p-6...adapter-p14735
Thanks,
Jack
Old 03-13-2012, 11:52 PM   #19
Rewards Points: 4,578
nobody's house conc is that hard because no contractor or homeowner would spend the $ necessary to make it so,,, more than likely you're running into superhard coarse aggregate & it may be a dense mix of aggregate/cement paste - that's all conc is - cement, water, fine aggregate ( sand ), & coarse aggregate ( crushed rock ).
let me echo the ' chicago ' brand from whereever - its junk however it may last long enough to finish your work. IF it has the jacobs chuck, don't expect much - either spline, sds, or sds improved are necessary for your work - smooth bits are impossible to tighten in the chuck when subjected to the hammer vibration.
have you considered sinusoidal anchors instead ? much faster
Old 03-14-2012, 08:10 AM   #20
The Chicago drill seems to be much better, goes through the concrete like wood. I did snap a bit after 20 or so holes though. It has an SDS plus chuck, which is so much easier to work with, I was tightening drill bits every five minutes with the hammer drill.
I agree that you get what you pay for with power tools, but budget was a priority on this one. K just won't use it much after this part of the project. It was cheaper than renting.
I am concerned with the broken bit, it was around $5, I might try another brand at lowes. Hopefully it was just a problem with that particular bit.
Jack
Old 03-14-2012, 08:14 AM   #21
I will have to research the anchors, but I have 400 ultra cons now. The drill makes it much more doable. I got a full 4 by 8 screwed down last night in half the time it took to fasten 2 screws previously.
Jack
Old 03-14-2012, 02:33 PM   #22
Tool Geek
PaliBob's Avatar
I did not understand that reference to "sinusoidal anchors" in post #19
Nor did Google point me to any suppliers that would help in your application.
In my location I had not seen the Ultracon brand masonry screws but their web site shows an impressive history:
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-14-2012, 03:27 PM   #23
Same here on the anchors.
As for ultracons, there seem to be the same quality level as tapcons and they are a lot cheaper.
Jack
Porter-Cable or Craftsman Drill Dilema cprice12 Tools 19 02-16-2012 07:00 PM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 01:20 PM
Chiseling & chipping concrete with hammer drill. halapeno Building & Construction 0 05-24-2011 02:08 PM
Best (easiest) way to drill into poured concrete wall Todd-sta Building & Construction 11 11-16-2008 03:57 PM
