Best Concrete Wall Sealant? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-09-2014, 11:31 AM   #1
Rewards Points: 29
Best concrete wall sealant?
Has anyone used Super Thoroseal or Radonseal Plus for their poured concrete walls in their basement? I'm also planning on using Epoxy-coat for the floor. Would these products work to create a dry semi-finished basement?
chemteacher03 is offline   Reply With Quote
Old 02-09-2014, 12:02 PM   #2
Rewards Points: 13,296
Water proofing should be done on the outside of the walls.
There is no way to water proof the floor.
Do you have any drain tiles under the floor?
Is there a sump pump?
Is there gutters, outside grade running away from the foundation?
No mulch or flower beds forming ponds?
chemteacher03 (02-09-2014)
Old 02-09-2014, 12:17 PM   #3
Rewards Points: 29
Do you have any drain tiles under the floor? Yes
Is there a sump pump? Yes
Is there gutters, outside grade running away from the foundation? Yes
No mulch or flower beds forming ponds? No
I am just trying to make sure the basement remains dry. So put nothing on the walls?
Old 02-09-2014, 08:59 PM   #4
Rewards Points: 154
He is saying check everything else he said first. In most cases if that is all in order you should be good. If you still have water issues you either need to excavate and seal outside or else look at more drainage options.
In my opinion if water ever really does become a problem you're better off letting it all the way in than trapping it inside the wall with an inside wall-coating so the freeze/thaw cycles can compound the damage. Regardless, the masonry coatings will flake right off if there is serious water seepage.
eharri3 is offline   Reply With Quote
Old 02-09-2014, 09:32 PM   #5
Trucon01's Avatar
Rewards Points: 510
I agree with waterproofing from the outside, but in my case, there was no way I could deal with the expense.
So I did use RadonSeal 2-3 coats then used DryLok Extreme 2-3 coats. I have pics of this on my basement remodel link in the signature, page 5
Good luck
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 02-10-2014, 04:13 AM   #6
Rewards Points: 4,534
RadonSeal & DryLok Extreme no wonder i have trouble makin' my boat pymts - all the diy'ers think apron/vest store stuff really works here's an idea - IF those products were really effective on the inside, what about all the water that penetrates the wall to the point of meeting the applied coating ?
' pay us now OR pay us more later ! ' ( forget who said that but his boat was bigger than mine )
Old 02-10-2014, 06:52 AM   #7
Rewards Points: 29
And that is why I was wondering about the sealer in the first place. I heard that it is best not to paint/seal the walls because it will trap the water inside the concrete and have nowhere to go causing more damage within the wall.
Old 02-10-2014, 07:06 AM   #8
soil acids attack conc's lime & will eventually cause degradation of conc however damage is not immediately severe,,, i run a dehumidifier
Old 02-10-2014, 09:32 AM   #9
Rewards Points: 29
I run a dehumifier now as well. It collects 1 full bucket in 2 days during a hard few days of rain. I have a sump pump, french drain, drain tiles around the entire wall, good grading, and downspouts directed far away from the foundation. I just wanted to make the basement appear more "finished" yet not have to frame it and put up drywall.
Old 02-10-2014, 09:41 AM   #10
Dry Lok needed to be applied to the bare concrete to work.
Read the can.
Old 02-10-2014, 01:49 PM   #11
Rewards Points: 29
So Joecaption, should I or shouldn't I Drylok the exterior walls of my poured concrete basement?
Old 02-10-2014, 02:53 PM   #12
forget that stuff & use thoroseal, xypex, or kryton instead,,, no, you won't find them @ the apron/vest stores,,, ' dry*** ' is for ,,,,,,,,,,,,,,,,,,, [ better not say ],,, suffice - i'm not a fan
Old 02-10-2014, 04:52 PM   #13
Rewards Points: 154
You will need something heavier than dry lock for that job.
Old 02-10-2014, 05:07 PM   #14
Rewards Points: 29
I was thinking thoro-seal would be the best option.
Tags
epoxy , radonseal , thoroseal
How to make large doorway in load-bearing concrete block wall? hstraf Building & Construction 10 12-12-2013 02:48 PM
Basement - built wall 6" out from concrete wall Bill Shears Insulation 4 06-26-2013 02:00 AM
Frame Concrete Half Wall in Basement VikingDinKC Remodeling 6 03-09-2012 09:31 AM
How to insulate 1' concrete wall that meets 8' studded wall Truth Insulation 7 01-16-2012 09:14 PM
Exterior wall on concrete pad - waterproofing under wall? (Illustration included) JustADoc Building & Construction 12 08-18-2011 06:07 PM
