Best Concrete Mix For Interior Concrete Block Parge? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-22-2012, 02:07 PM   #1
Trucon01's Avatar
Rewards Points: 510
Best Concrete mix for interior concrete block parge?
Hi All,
Could someone point out the best product from the following site to parge an interior concrete block wall?
http://www.homedepot.com/webapp/cata...g#/?c=1&rpp=96
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 07-22-2012, 03:52 PM   #2
Rewards Points: 152
Use portland cement type 1/2 with sand.
TRUEPRO is offline   Reply With Quote
Old 07-22-2012, 06:05 PM   #3
Trucon01's Avatar
Rewards Points: 510
Thanks, but I was planning on doing a 1/2 coat then a second 1/2 coat. Portland cement is for 2+ inches, right?
Old 07-22-2012, 06:28 PM   #4
Rewards Points: 152
No it can be used up to 2". But your only gonna get a 1/4 parge anyways anymore then that it will sag and ripple. Your should also look into bonding agent as well.
Old 07-22-2012, 07:44 PM   #5
Trucon01's Avatar
Rewards Points: 510
Maybe I'm looking at a different type... The description on the port. cement says
"Portland cement is used to make concrete where 2 inch thickness or more is needed to build or repair walks, floors, footings, patios, setting post and poles. This is pre-blended for a consistent quality"
http://www.homedepot.com/Building-Ma...&storeId=10051
Old 07-22-2012, 08:08 PM   #6
Rewards Points: 152
Read again... . "Portland cement is used to make concrete where 2 inch thickness of more is needed to build or repair walks, floors, footings, patios, setting post and poles"
"Also can be used for base coats"
"Walks, floors, footings, patios, post/poles" This doesnt apply to you. Thats ALL ground work.
Dont recommend sakrete. Use Roanoke Portland type I/II. You have to buy sand as well to mix. You can try the premix first and if you dont like the results then go with my way. GL
Old 07-23-2012, 06:38 AM   #7
Trucon01's Avatar
Rewards Points: 510
Sounds good. So maybe something like this would work?
Old 07-24-2012, 07:50 PM   #8
Rewards Points: 152
Sure give it shot and let us know your results!
GL
Old 07-25-2012, 03:41 PM   #9
Concrete & Masonry
Rewards Points: 582
You won't have any success with that stuff, it's meant fro patching horizontal surfaces and has no lime in it, which is what you really need.
As for what type of mortar you need, it really depends on what the current issue with the wall is, and what you're trying to accomplish with the plaster.......
jomama45 is offline   Reply With Quote
Old 07-27-2012, 09:50 AM   #10
Trucon01's Avatar
Rewards Points: 510
For my interior basement block walls, I wanted to put a parge coat on a few sections (top to bottom). Some areas have light to moderate cracks. I got a bunch covered with Hydraulic Cement already, but wanted to put a full coat over the whole wall now.
Can you tell me what to look for specifically? I looked at the HD site and nothing says it includes lime. Do all Type S mixes use lime?
http://www.homedepot.com/Building-Ma...1#.UBKeC0RaJ50
Old 08-09-2012, 10:29 AM   #11
In cement plaster, the less lime the better. Lime improves workability, at the expense of strength, and shrinkage.
There are specialized lime plasters, but thats not what you are doing.
Type S mortars are generally a bit higher strength with added latex for below ground applications, and contain lime.
Clean and bond the entire area. Use 2 coats, first coat scratch horizontally, let dry, then the second pull tight and double up. If you dont mix too wet, and dont apply too heavy, it may not check. Floating with a wood or hard rubber float near the end of cure while still workable, will compact, bring up sand, and make a better finish. Use as little water as possible.
good luck
jmagg is offline   Reply With Quote
Framing a wood studded wall against a concrete block wall miamicuse Remodeling 22 01-21-2014 09:20 AM
Best way to fasten 1x2 furring strips to concrete block walls miamicuse Building & Construction 10 05-02-2012 12:12 AM
concrete block house shower medalta Building & Construction 3 11-02-2011 05:16 AM
Bathroom Remodel - Resurfacing Plaster over Concrete Block itcanadian Remodeling 2 05-30-2011 10:10 AM
New window in concrete block wall swill777 Building & Construction 3 08-02-2010 01:28 PM
