Basic Concrete Block Repair - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-07-2012, 08:09 PM   #1
Hi,
I need to repair the joints in a masonry concrete block wall and wondering what is the best material to use for the strongest repair. The advice I've had so far goes something like this:
1. Remove old mortar with chisel
2. Apply concrete adhesive to the joints since it is old concrete
3. Use some of the regular concrete repair mixture from Home Depot ( ie, not necessary to us mortar ). Mix it up using the concrete adhesive to make it really strong.
4. Force into the joints with trowel.
Thanks for advice
Mike Mike is offline   Reply With Quote
Old 05-07-2012, 08:13 PM   #2
Rewards Points: 13,748
Did someone at the box store tell you this info?
Need to post a picture for some better advice.
Old 05-07-2012, 09:44 PM   #3
Concrete & Masonry
Rewards Points: 582
I'd simply chisel out the old mortar until you get to clean material, and replace with new mortar. Unless you plan to replace all the mortar on every wall, the wall's only going to be as strong as the weakest mortar. And, using repair material that's stronger than the concrete block tends to compromise the integrity of the block through time.
jomama45 is offline   Reply With Quote
Old 05-08-2012, 08:08 AM   #4
Rewards Points: 152
Use the original Type S mortar that was used for this block wall. Chisel clean. If the block is seen, the take care not to smear mortar all over the wall. You could even use a grout bag to fill the joints back it. Good luck.
TRUEPRO is offline   Reply With Quote
Old 05-08-2012, 02:33 PM   #5
Thanks for the replies. One more question.
I've also heard that it is a good idea to wet the block first to keep the blocks from sucking the moisture from the mortar. And it's even a good idea to keep the mortar damp by misting periodically.
Is this necessary ?
Old 05-08-2012, 02:45 PM   #6
Rewards Points: 528
Not necessary, but good practice dictates that.
framer52 is offline   Reply With Quote
Old 05-08-2012, 03:38 PM   #7
Ravenworks's Avatar
And what motar falls to the ground leave it there until it has dried or you'll have a real mess.
Ravenworks is offline   Reply With Quote
Old 05-12-2012, 05:11 PM   #8
Also, is there a way to fix cracks in concrete blocks ?
Epoxy ? If so, is it available in small quantities for the DIY guy ?
sawing concrete block: concrete saw or masonary blade? itsnotrequired Concrete, Stone & Masonry 10 05-08-2012 08:05 AM
Replace or Repair some old 4x4's in concrete?!? atmcl Carpentry 3 06-05-2011 01:57 AM
concrete block detached building, minimum space between openings rich624 Building & Construction 2 11-22-2010 07:48 PM
Hole in concrete block wall jjrbus Building & Construction 4 06-05-2010 01:32 PM
Concrete chip repair prior to ceramic floor tile? libbybuddy Flooring 2 06-10-2009 04:54 PM
