Basement Window Sill - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-01-2012, 10:06 AM   #1
Where the ground meets my basement window, there is about a 2" concrete sill that is broken into about 5 pieces, exposing the tops of the cinder block wall (explains why water was coming through despite my drainage efforts). How can I go about repairing this? Obviously I can't spread concrete directly over the blocks, so what do I need to put down before the concrete?
Thanks!
busterbluth123 is offline   Reply With Quote
Old 09-01-2012, 05:39 PM   #2
Rewards Points: 3,834
Thanks!
You can spread concrete over the blocks if you stuff the openings in the blocks with a filler, crumple up some plastic bags,or use bubble wrap to fill empty space,where there's a will there's a way.
Canarywood1 is offline   Reply With Quote
Old 09-01-2012, 05:54 PM   #3
Rewards Points: 14,312
Posting a picture so we can see what your seeing is always helpfull.
Old 09-01-2012, 06:00 PM   #4
Fill any void with expanding spray foam, then cement it.
NECHater is offline   Reply With Quote
Old 09-01-2012, 06:52 PM   #5
Without that picture it's hard to say exactly. But instead of filling blocks that may well leak I'd concide using a cap block instead. Better look and less likly to leak.
http://www.bing.com/images/search?q=...991CE7EB583961
Old 09-04-2012, 08:46 AM   #6
Concrete & Masonry
Rewards Points: 650
Are you sure it's actually a concrete sill and not just a mortar "wash" over the block? If you have the room, a one-piece stone sill (like what joecaption linked to) would work well.........
jomama45 is offline   Reply With Quote
HELP! Water Leaking Into Basement Window COPYCAT Building & Construction 5 03-23-2011 04:57 PM
Basement window replacement Atskodinski Building & Construction 9 03-21-2011 03:26 PM
my fix for rotting outside sill on wooden window guest General DIY Discussions 6 11-06-2010 02:58 PM
box around window in basement BlueBSH Carpentry 2 10-08-2010 12:11 PM
Sill on aluminum window danvath Building & Construction 1 09-20-2010 09:45 PM
