Basement Waterproofing - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-24-2012, 09:23 PM   #16
Concrete & Masonry
Rewards Points: 470
Originally Posted by indep View Post
Can you elaborate on the wall bowing issue? Now this part I am not aware of, if the wall is bowed or not, so how do I go about this? because I'm worried with time, since there is no waterproofing of any kind around the house that eventually water will find its way in some place that hasn't been waterproofed, but I also don't want to weaken the foundation if the walls are bowing...any suggestion would be appreciated
A 6' level, or a long straightedge and shorter level. Check the interior plane of the wall vertically in a few spots and see if there's any deflection. In my experiences of repairing block walls professionally, excavating/removing the soil from the exterior only removes the lateral pressure and the wall slowly returns to wards it's original position on it's own. Can't say I've ever seen one worse after excavation, but i suppose with an erratic operator on a piece of heavy equipment, it's possible.
jomama45 is online now   Reply With Quote
Old 09-25-2012, 09:54 AM   #17
The neat part with this house is that it's sitting on bedrock, which helps with the settling. If the excavating (assuming it's done properly, i'll do my due diligence in hiring someone qualified) is done properly, then as Jomana mentioned, it shouldn't make it worse... hopefully
I'll talk to a civil engineer and see what he has to say as well, next time he's in town
indep is offline   Reply With Quote
Old 09-25-2012, 11:33 AM   #18
concretemasonry's Avatar
Rewards Points: 2,566
The fact that you are just above rock increases the problems since the water will most likely have no place to go and probably increased the soil pressure on the wall and also could cause more leakage and some bowing.
You probably did not "fix" the real leak, but eliminated where the water showed up inside. You could end up chasing leaks all around the basement and then end up with the final "leaks" showing up at the joint between the wall and interior slab or the pressure causing slab cracks that can leak. It is a normal progression in many homes.
Drain tile and proper bedding and backfill will eliminate the excess water and reduce the soil pressure on the wall and slab. - Either interior or exterior, but no stick on water collectors around the basement that just collect the water after it has leaked into the living space. A proper interior drain tile system will lower water level long-term as well as an exterior system and may be cheaper if you have landscaping, sidewalks, patios or attached garages since water moves horizontally and in some cases upward by capillary action.
Dick
concretemasonry is online now   Reply With Quote
Old 09-28-2012, 08:41 AM   #19
That is quite an involved process for a basement leak! Typically, water enters into the basement through one of two ways (sometimes both): 1) crack in the basement wall or floor, or 2) concrete pores. Most hairline cracks and cracks measuring up to 1/2" can be repaired using a high pressure hydrophobic polyurethane crack repair kit - they make them for DIY users. If the crack is in need of structural repair and is not leaking, an epoxy could be used. Next, you want to use a penetrating, permanent waterproofing sealer kit which can be applied on the interior of the basement. Seal your walls and floors with it. For added protection, you can use a surface waterproofer once the pentrant has had time to cure. Sump pumps can be added to your basement but those only come in handy once water has already entered. You can add a waterproofing membrane to the exterior but that isn't always needed and can eventually breakdown. Before investing any more money, I would find the source of the leak and determine if all the work you are doing is even necessary.
Last edited by beenthere; 09-28-2012 at 03:45 PM. Reason: removed multiple links to his business in post
FoundationArmor is offline   Reply With Quote
Old 09-28-2012, 09:46 AM   #20
You just have to look at what is causing the leaks. - It is not as simple as putting or slopping on some stuff for a lifetime guarantee.
In over 40 years of being involved in design, construction and consulting, I have never seen a single products that does an adequate waterproofing job, because the causes are so different - climate, soil types/layering, hydrostatic pressure, soil pressure, cracking, settlement and vagueness of the original construction.
Sump pumps can be great because they a positive method to remove water BEFORE it gets into the living area. Since water does not follow a "neat" gravity-only law, the water and pressure commonly is from below the building "footprint".
Dick
The Following User Says Thank You to concretemasonry For This Useful Post:
allthumbsdiy (09-28-2012)
Old 09-28-2012, 06:35 PM   #21
LThanks guys, the original leak was fixed but I figured the membrane will help any future potential leak
Old 09-28-2012, 07:34 PM   #22
Here are some photos of the foundation
Basement waterproofing-20120915_103902.jpg   Basement waterproofing-p7020040.jpg
waterproofing a basement PorgyLuvzBess Building & Construction 5 08-30-2011 07:55 PM
Basement Waterproofing jgfranklin Plumbing 21 08-05-2011 12:24 PM
Advice about Waterproofing Basement Walls Firehawk734 Remodeling 2 12-08-2010 04:23 PM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 09:49 AM
basement waterproofing nlexi912 Building & Construction 6 12-31-2006 12:27 PM
