Basement Water - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-20-2012, 11:25 PM   #1
Does anyone know anything about hyper barric pressure on basement walls and floors? My inspector said that's what's causing water in my basement. Any suggestions???
Sent from my iPod touch using DIY Forum
slimcutta is offline   Reply With Quote
Old 07-22-2012, 02:20 PM   #2
Trucon01's Avatar
Rewards Points: 510
You sure it wasn't Hydrostatic Pressure?
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 07-22-2012, 03:55 PM   #3
MarginallyQualified
Rewards Points: 2,464
Any suggestions???
If you have hyperbaric issues in your basement...
I suggest you get dive certified real soon
Old 07-22-2012, 08:08 PM   #4
Hydrostatic must have been the spell check. Haha
Old 07-23-2012, 07:47 PM   #5
Trucon01's Avatar
Rewards Points: 510
A good start would be to read:
http://www.berkeleydailyplanet.com/i...By-Matt-Cantor
Old 07-23-2012, 08:11 PM   #6
I understand that. It helps but this house was sitting for 2 years without the downspouts on. When we put them on I have not seen water since. Could that have been a big part of the problem???? Could that have risen the water table???? Thank you for the answers so far!
Old 07-24-2012, 06:52 AM   #7
Trucon01's Avatar
Rewards Points: 510
Certainly, gutters, grade, etc. All could be culprits. This weekend I'll be adding a weeping tile system in my basement for extra measure. Once I'm down to the footer, I will be drilling out the cavities in the wall blocks to relieve any hydrostatic pressure and to eliminate it in the future.
Old 07-24-2012, 09:54 PM   #8
Is that a beaver dam? Where it goes along the inside of the wall. I have that too and it runs to 2 sump pumps. I'm hoping it was the gutters that were the problem.
Old 07-28-2012, 10:02 PM   #9
Old 07-29-2012, 01:28 AM   #10
Rewards Points: 83
Yes. That is a beaver dam.
rubberhead is offline   Reply With Quote
Old 07-29-2012, 01:28 AM   #11
Rewards Points: 83
[QUOTE="rubberhead"]
Yes. That is a beaver dam.[/QUOTE
Old 07-30-2012, 03:44 PM   #12
Help with your basement questions by Ameri-Dry Guy
I think what you mean is hydrostatic pressure. That is when water accumulates around the outside of your foundation walls and creates pressure two ways; first is simply by taking up the available space and increasing the amount of weight that sits against your walls and secondly is if you have clay soil around your foundation than that will actually absorb the water expanding its size and actually pushing the wall inward.
Hydrostatic pressure can cause major issues for your homes basement, foundation in crawlspace. You should contact a licensed waterproofing contractor immediately to asses the situation.
Ameri-Dry Guy is offline   Reply With Quote
Water leaking in through door on main floor down to basement. DIYinTraining Building & Construction 15 12-14-2011 06:24 PM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 10:08 AM
Need help figuring out walk-out basement water intrusion issue toomanypets General DIY Discussions 18 08-29-2011 08:34 PM
Advice for a novice: Mold and water damage in basement xoxJanette General DIY Discussions 1 12-29-2009 06:54 AM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
