Basement Walkup Stairs - Ice - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-24-2014, 04:36 PM   #1
Rewards Points: 1,088
Basement walkup stairs - ice
With the recent storms, I have ice on the stairs. Has anyone used any type of heat tape or wire and placed this on their exterior stairs to get the ice to melt?
Any other suggestions beyond propane torch, hot water, etc.?
handy man88 is offline   Reply With Quote
Old 01-24-2014, 06:06 PM   #2
Rewards Points: 1,008
Being the temperature is below freezing any melt water is likely to cause problems in other areas when re-frozen. I'd be inclined to try sand, salt or cat litter and get a firm grip on the hand rail.
The Following 3 Users Say Thank You to SeniorSitizen For This Useful Post:
Bondo (01-25-2014), concretemasonry (01-24-2014)
Old 01-24-2014, 07:03 PM   #3
The melted water would go directly into the drain on the bottom of the walkup and into the house to the sump pit. There isn't a lot of ice. Just enough to make the area slick.
I don't want to use any chems or anything granular because it would wash into the drain into the sump pit.
I'm not trying to get traction. I just want the ice to go away.
Old 01-24-2014, 07:16 PM   #4
Rewards Points: 154
Able to get a space heater into the area?
eharri3 is offline   Reply With Quote
Old 01-24-2014, 07:24 PM   #5
It's an outdoor basement walkup. The atmosphere would absorb all the heat and space heaters are generally designed for near water use.
Think of it like in the movie Home Alone where Daniel Stern is walking down an icy stairs to the basement door.
Old 01-24-2014, 08:05 PM   #6
joed's Avatar
Rewards Points: 12,450
Salt will not harm your drain.
The Following 2 Users Say Thank You to joed For This Useful Post:
Bondo (01-25-2014), handy man88 (01-24-2014)
Old 01-25-2014, 08:13 AM   #7
Rewards Points: 236
true. not only that, it could be good for it. if there are roots grounding in/around the pipes, the salt will deter the roots.
Fix'n it is offline   Reply With Quote
Old 01-25-2014, 08:21 AM   #8
The drain on the bottom of my stairs is a catch basin with pvc that routes the water to my sump pit in my house.
I'm also a bit wary of putting down too much calcium chloride on my concrete stairs.
Is magnesium chloride better for concrete?
Old 01-25-2014, 03:55 PM   #9
Rewards Points: 4,586
IF i remember correctly, stern fell,,, that's why holding onto the handrail is such a good suggestion,,, hot wtr won't help - by the time you melt the ice, it'll leave a slick surface anyway,,, calcium chloride's fine but like salt, if too cold, won't work either,,, brine from cheesemaking's been shown to be a good icemelter OR you could install some bilco doors [ no $ interest ]
Old 01-25-2014, 05:54 PM   #10
I want to get rid of the ice not because the stairs is used frequently, but because I want to get rid of the ice.
I put down some CaCl and a few hours later, I was able to chip away some of the softer ice. The BJ's brand says it works down to -25F.
Old 01-26-2014, 08:28 PM   #11
Rewards Points: 3,530
All CaCl will work down to -25,salt needs 20 degrees and rising to be effective.
Canarywood1 is offline   Reply With Quote
Old 01-28-2014, 08:35 PM   #12
Concrete & Masonry
Rewards Points: 548
Absolutely not, it's even worse for concrete. If you want something effective, and you already have the CC, take 2 pails, mix 25% CC and 75% water back and forth between the pails until the CC completely desolves. Start at the top and pour a little bit down the steps. If you're still leary to use the liquid, get some plain ole rock salt (sodium chloride) and pour some of the CC liquid over it and get the best of both worlds. It's not unsafe in any way, as the municipalites around you use tons of it a year with no major issues......
CC is rarely used by itself, it's almost exclusively mixed with rock salt. Regular old rock salt works well below 20 degrees as well, we haven't been above 5 degrees here for a few days, and the rock salt has melted millions of acres of pavement in the last few days in my area..........
jomama45 is offline   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Basement stairs against concrete wall ChrisWz Remodeling 9 12-23-2012 09:36 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 08:55 AM
Outside basement stairs, bulkhead stairs, etc anesthes Building & Construction 0 03-29-2011 05:33 AM
Basement Stairs/ EZ Stairs mjkpainting Carpentry 8 02-24-2010 09:24 PM
