Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-02-2012, 03:53 PM   #1
basement footings
our footings extend beyond our centre basement bearing wall(about 2"), is it ok to remove a portion of the footing measuring 2"w x 1 1/2 " d x 10ft long.This would allow installing baseboards.Tks.
jecuec is offline   Reply With Quote
Old 03-03-2012, 06:21 AM   #2
Concrete & Masonry
basement footings
No.....
jomama45 is online now   Reply With Quote
Old 03-03-2012, 08:35 AM   #3
Stay-at-home GC
basement footings
Maybe.....
do you have pics?
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 03-03-2012, 09:22 AM   #4
Disabled wood vet
titanoman's Avatar
basement footings
Yes...as long as you leave the 3 or 5-1/2" under the wall.
It's just a curb to control toxic chemical spills and water, although we just box them out when we trim.
Except: If there's a curb on the house wall, leave it alone (it's code)
Keeps flammables (gas) from seeping into or under your house.
titanoman is offline   Reply With Quote
Old 03-03-2012, 12:03 PM   #5
Stay-at-home GC
basement footings
Is it part of the footing? It would be unusual to be able to see the footing in the basement unless it is a monolithic slab pour (even then, unusual).
My guess would be (and without pics its just a guess) is that the center of the house bears on steel with a post or two. The "Center Bearing Wall" is just a partition and the "footer" was formed as part of the slab pour and is not structural.
It is there for the reason Titanoman pointed out.
Old 03-03-2012, 02:00 PM   #6
basement footings
Thanks everyone for you replies.. our house was built in 1978, so its not built by todays standards. that why we are concerned about removing part of the wall footing.. its an 8 inch footing sitting above the basement floor. Our wall is 6 inches wide so their is that awful 2 inches of footing exposed, making it difficutt to put on proper mouldings... with the extra info, are you answers still the same.. let me know, appreciate you input ..jecuec
Old 03-03-2012, 02:16 PM   #7
Stay-at-home GC
basement footings
Generally your footing will not be visible from inside the home (some pics would help).
If it's not a footing then what is it? Until we know we can't say for certain if it is safe to remove some of it.
Options:
1: Some kind of weird inverted slab/footing
2: The real footing with the top left exposed
3: A non-structural curb for flammable/toxic gas codes
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 11:08 AM
what's the consequences of a well insulated basement diy001 Building & Construction 1 06-12-2011 02:13 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
