Basement Floor - What Type Of Concrete To Use? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-08-2012, 03:02 PM   #1
Basement floor - what type of concrete to use?
I'm installing a bathroom in my basement. I broke up the existing concrete and dug everything out to get the drainage pipe in, now I've got to fill it back in. I broke the old stuff with hammers so it's pretty jagged and uneven. Would a general use concrete suit the job or do I need to go with something more specific?
Also, any idea how much I'll need. It's broken up roughly in a T-shape, one run is 7 ft x 12 in, the other run is 5 ft x 18 in, and it was about 3 inches thick.
Thanks.
Evilhomer is offline   Reply With Quote
Old 09-08-2012, 05:53 PM   #2
Rewards Points: 3,630
Thanks.
You'll need 9 or 10 60lb bags of sakcrete if your demensions are accurate.
Canarywood1 is online now   Reply With Quote
Old 09-09-2012, 11:24 AM   #3
World's Tallest Midget
Mort's Avatar
Rewards Points: 692
If it says you need 9 or 10, get 11 or 12. Trust me on this one.
And just your average bags of Sakrete at Hombre Depot will do nicely. It doesn't need to have air entrainment, just make sure its not a sand-only mix.
Mort is offline   Reply With Quote
Old 09-09-2012, 10:31 PM   #4
Thanks, 7 bags did the trick.
Old 09-12-2012, 03:39 PM   #5
Rewards Points: 4,656
@4" depth, ea 80# bag yields 2sf OR .67cf,,, @3" depth, the yield is the same BUT you'll fill 25% more sf - just like coffee, throw in an extra b for the pot ;-) forget the bag's compressive strength but don't add more wtr than nec OR you'll lower the strength of the conc
Demolishing Basement Concrete Slab... CarlsonRower Remodeling 21 03-21-2012 07:46 AM
Frame Concrete Half Wall in Basement VikingDinKC Remodeling 6 03-09-2012 08:31 AM
Painting concrete basement floors shimga Flooring 3 04-24-2010 02:46 PM
Basement concrete floor repair estimate ControlTech Building & Construction 1 04-10-2010 07:28 AM
subpanel mounting on concrete basement foundation wall bulk88 Electrical 12 03-10-2009 01:38 PM
