01-20-2013, 10:11 AM
#1
basement floor cracks, problem?
Hi,
In the Chicago suburbs in a 6 year old home. I see basement floor concrete cracks extending from every support column.
1) Are these cracks an issue to be worried about?
---no moisture, even under saran wrap taped to floor.
2) If I finish and carpet over, do these cracks need to be filled, and with what?
---Caulk, dryloc floor paint, something else?
3)I had thought about painting the floor solely for concrete dust and/or filling the cracks
(see #2) HOWEVER if I use a subfloor system (Delta, dricore, tyroc) can I leave the floor AS IS? No painting, no filling of cracks?
01-20-2013, 10:24 AM
#2
Hard to tell from that close up.
It's normal for some settling cracks to form. That one in the picture is I'd figure on seeing a crack.
01-20-2013, 10:33 AM
#3
Would another picture help? Was it blurry, not close enough....it's easy enough to go take another picture just let me know what is helpful.
I have about 6 columns in the basement, all with 4 cracks extending out from each other to each other.
01-20-2013, 10:48 AM
#4
That would be normal and not need filling.
01-20-2013, 11:28 AM
#5
Do you know when those column's were put in??
01-21-2013, 10:14 AM
#6
The home was new construction, 6 years old now.
The concrete guy was awful and made some other goofs on the foundation.
01-21-2013, 10:46 AM
#7
they're called re-entry cracks & typically found when no isolation jnt surrounds the column foundation,,, expect your supporting foundation(s) is at the same elevation as the top of footing,,,the floor ( floating slab ) was then install'd,,, in fairness to the conc sub, that may've been as order'd by the bldr,,, if you find finishing issues w/floor's surface, THEN blame the conc sub many conc subs don't excavate footers but just form, set rebar, place, & finish the conc
don't see any indication of movement which'd manifest itself by spalls on the crk edges therefore no movement has occurred,,, you'd expect no movement in a bsmt due to temp differentials as the humidity/temp are fairly constant.
IF it were ours ( & we have 'em, too ), smear some acrylic caulk over 'em to keep out rising dampness then finish your floor
IF a proper jnt pattern had been included along w/isolation jnts, there probably wouldn't have been any random cracking however we typically only see that addl expense w/commercial & industrial work
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders ! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
01-21-2013, 12:51 PM
#8
"many conc subs don't excavate footers but just form, set rebar, place, & finish the conc "
And that's why those cracks are there,footings should have been excavated,really sloppy way of doing the job.
01-21-2013, 05:43 PM
#9
Concrete & Masonry
As straight as those "cracks" are, I'd bet that they actually used "Zip Strips", which are fairly common and completely acceptable from a non-asthetic standpoint. The likely reason you're not getting any moisture on Saran wrap is because it has plastic sheeting/Visqueen under the floor for a vapor barrier, which is required by code in most, if not all, of the Midwest under baesment floors. I see nothing alarming about anything in the pictures, and don't know of anything you could do to improve the non-issues before moving forward with flooring........
http://www.brockwhite.com/0p14i4357/...-joint-former/
01-21-2013, 05:44 PM
#10
good point, jo, & a definite possibility,,, impo, crks are due to reason previously post'd,,, how to proceed was original post & an answer's also post'd above,,, its conjecture to say excavation/footings were sloppy/properly built, postfoundations don't exist, or place blame w/o supporting data,,, it is what it is as ' those guys got paid & they're gone ! ' rule now applies,,, also post'd my solution were that floor mine
40yrs i've been doing this work & still can't look thru floors OR walls just have to depend on my experiences,,, when all's said & done, more is said than done,,, btw, i like jo's theory better'n mine but still conjecture w/o excavation
01-21-2013, 07:04 PM
#11
If the columns/post were on footings a good contractor would make tooled joints toward the columns leading to a classic diamond pattern to eliminate random ugly cracks.
If there is no difference the floor height on the adjacent sides of a crack, it is probably a cosmetic problem since a basement slab does not move much.
Dick
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
