Basement Concrete Curb - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-30-2013, 04:24 PM   #1
"You can do anything"-Mom
brockmiera's Avatar
I have a center load bearing wall that is framed and runs the length of my basement. Under the partition wall is a 4" tall concrete curb. I am putting a closet door opening in that load bearing wall. rough opening will be 32"
How would I go about cutting out that section of concrete curb?
brockmiera is offline   Reply With Quote
Old 01-30-2013, 05:12 PM   #2
Rewards Points: 660
I believe I have the same type of basement. I believe that it is a 4" x 8" x 12" concrete block sitting on the footing with the slab poured around it. i secured the joists with bottle jacks, cut out the bottom plate and studs in the way, and used an angle grinder with a diamond blade to cut the block out. It creates a crapload of dust so wear a mask and have a window open.
I then framed in the doorway with 4x4 posts on each side and a 4x6 header. I tend to over build. Then I looked at the doorway to the utility room about 10 feet down and it just had a 2x4 on each side with not much more than that above the door.
B
Beepster is offline   Reply With Quote
The Following User Says Thank You to Beepster For This Useful Post:
brockmiera (02-06-2013)
Old 01-30-2013, 05:21 PM   #3
brockmiera's Avatar
Ha ha ha. Thats hilarious. I was there with my IBC Span charts figuring out how to support the wall. Cutting out top plates, double 2x6 header, number of jack studs when my girlfriend says, "Hey, why dont you just do it like this one?" sure enough down the wall are two different framed openings with a 4x4 stuffed under the double top plate with a 2x4 on either end.
My curb is a little differend though. Its 4" tall x 3.5" wide. Its poured concrete not CMU. I figured I'd use an angle grinder and diamond blade but I'll only be able to get down maybe 2" with the 4 1/2" grinder. Planned on using some water to keep the dust down. Should I use a cold chisel on the rest of the removal after I've scored around the whole thing?
Old 01-30-2013, 07:35 PM   #4
Rewards Points: 13,274
Do not use 4 X 4's or 4 X 6's for framing.
Both after a while will check along there length and like to twist or curl.
Use double up 2 X 4's instead. For the header use 2 X 6's with 1/2 plywood or OSB in the middle. That way it will come out even with the sheetrock.
oh'mike (02-07-2013)
Old 01-31-2013, 10:06 AM   #5
Rewards Points: 660
I have since learned that two 2x4s (or 6s) are stronger than one 4x4 (or 6). Who knew? Nobody told me. The best advice my old man imparted on me was to never get married. Uh...ok...can I finish watching Scooby Doo now dad...
B
Old 01-31-2013, 10:12 AM   #6
brockmiera's Avatar
So I dont have enough headroom under the double top plate to put in a 2x6 header. Since I'm only spanning two joists will a 2x4 header work? I'll have to remeasure the height. Maybe I can rip a 1/2" off of a 2x6 and get 5" in there.
Old 01-31-2013, 10:46 AM   #7
Got a picture?
For that short a distance it should be fine.
Old 01-31-2013, 10:50 AM   #8
brockmiera's Avatar
No but I'll take one tonight when I get home and post it.
Old 01-31-2013, 11:24 AM   #9
Rewards Points: 4,534
make your cuts w/diamond blade on the grinder - 1 vert at ea end AND 2 horizontals 1 on either side of the curb,,, then use a sm chipping gun ( bosch bulldog type ) w/1" chisel bit & bushing tool,,, vac would help trap what dust there is
ixnay on the wtr UNLESS you have a gfci on the tool's circuit
Old 01-31-2013, 11:55 AM   #10
brockmiera's Avatar
Ok I can do that.
I used an air hammer with chisel attachment to make a hole in the floor to replace my P trap. Do you think that would work ok so I don't have to go and rent something?
Old 01-31-2013, 12:26 PM   #11
unless you have lotsa air, it'll be slower & make more dust but if the ? was ' can i,,,, ? ' of course - ' ok ' is another matter - don't like air-powered dust-making tools in my house but its your house
Old 02-05-2013, 08:59 PM   #12
brockmiera's Avatar
Ok So i framed the opening and when I cut the sill plate out of the opening I found some concrete blocks that are hollow. Why would these be here?
Old 02-05-2013, 09:01 PM   #13
brockmiera's Avatar
Here are more pics
Old 02-06-2013, 12:18 PM   #14
brockmiera's Avatar
So I read back thru this thread and it looks like you were right after all Beepster. Once you got the block out of the concrete did you fill in the void left with new concrete?
Old 02-07-2013, 10:28 AM   #15
brockmiera's Avatar
I also noticed some metal shims, Im guessing, on the right side of the block in that photo. I'm guessing these were in place as forms for when half of the basement slab was placed. I'm also assuming there is a footer below them. If I remove these should I fill the void with concrete?
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 12:19 PM
Concrete Basement Floor Prep BillyPilgrim Flooring 3 10-12-2012 10:35 AM
Laminated flooring over basement concrete Woodcutter Flooring 2 10-25-2011 09:55 AM
Finishing basement - concrete walls options droyer Building & Construction 1 01-13-2010 07:27 PM
