Basement Cement Floor - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-03-2013, 12:03 PM   #1
Rewards Points: 105
Basement cement floor
I asked this in flooring but I think it's more appropriate to ask here.
Hello Pro's!
I need a sounding board for two different ideas I'm considering for my basement. I might also need to ask in the cement area of this forum. So I'm looking to finish my basement. My house is built in 1929 and has a very thin basement cement floor. I'm pretty sure it's more of a 1 inch dust cap rather than a real 4 inch cement floor. There are two areas on the floor that are badly bubbled and raised. They sound hollow. As well as some other smaller areas that have broken up and show the bit of gravel underneath.I don't seem to have any water issues and have never flooded, not even a bit. I'm in NJ btw.
I'm a bit torn here. I want to level the floor so I can install electric raident in floor heating and then tile. If I was going to go the less expensive and less difficult way I would break open the bad parts of the floor with a jack hammer and refill with cement. I would then lay down the heating sheets and cover the whole floor with self leveler, then latex modified thinset, then tile. Oh, I should also make mention that the previous owner painted the floor with some kind of epoxy paint. I would have to scrape that off with either a cement sander or something.. Suggestions please on what to use to that paint off.
OR
Go the expensive route. Pay someone of jack hammer the whole floor and lay a real 4 inch slab. While I was at it going this route, I may also go for French drains and have the rough in done for the basement bathroom leading to an ejection pump as the main drain is 6 inches above the floor. I might also be able to gain a valuable 2 or 3 inches as the current ceiling hight is around 6 foot 7 inch.
I'm looking for some feedback on this. Is the 1 inch dust cap with leveler and tile going to be ok or am I just throwing out Time, money, effort and will need to replace the whole slab anyway. Thanks for the input!
AdamBNYC is offline   Reply With Quote
Old 11-04-2013, 04:07 PM   #2
Rewards Points: 4,452
be ' torn ' no longer do it right the 1st time - go for the 4", drain, & rough in for the family room diamond grinders will remove the epoxy but we sometimes use beaneedoo, too
IF you're a pro, self-leveler will help BUT not on a 1" skim floor,,, all you're doing is wasting time & $$$ as eventually the rest of the floor will probably break up, too
ps - cement is an ingredient of concrete
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
Cement coating on block basement theedudenator Building & Construction 10 03-13-2011 08:18 AM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 01:23 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
