Basement Brick Wall - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-24-2012, 10:11 AM   #1
Basement Brick wall
Im looking to fix my basement walls due to some brick having spaces in them. I do not know what I need to do to fix this. Im getting ready to sell it, and my realtor said I need to fix the basement walls, along with the chipping paint. Can anyone give me any insite on what I need to do, perferably something easy. The bricks do look like they have been painted white. The house was built in the 20's. Thanks.
hardworknlady81 is offline   Reply With Quote
Old 05-24-2012, 11:57 AM   #2
Rewards Points: 660
This sounds like this is the perfect question requiring a picture. Not sure what you mean by spaces.
B
Beepster is offline   Reply With Quote
Old 05-24-2012, 12:31 PM   #3
I will upload pics as soon as I get home!
Old 05-25-2012, 09:28 PM   #4
I cant figure out how to upload the pic.
Old 05-26-2012, 03:40 AM   #5
Rewards Points: 582
You need to repoint them.
stuart45 is offline   Reply With Quote
Old 05-26-2012, 10:08 AM   #6
What does that mean?
Old 05-26-2012, 10:13 AM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 358
Ayuh,.... It means repackin' all the cracks/ seams with mortar, usin' tiny trowels
Old 05-26-2012, 10:15 AM   #8
Is there a certain kind that you use for that? Im not familiar with that kinda stuff.
Old 05-26-2012, 11:18 AM   #9
Bondo's Avatar
Rewards Points: 358
Ayuh,... I use type S for 'bout everything,...
But,... I'm NOT a Mason...
Old 05-26-2012, 12:36 PM   #10
Rewards Points: 3,370
Those look like they have been painted, how big of an area do you have to fix??
Canarywood1 is offline   Reply With Quote
Old 05-26-2012, 01:02 PM   #11
There are quite a few spots like that in the basement. thru out the entire basement which is 4 different rooms. some 2x2 areas 4x4 areas. Some areas are right by the door ways. it all has been painted.
Do I have any other options beside mortar? Im not looking to make the basement nice, I just need to fix some of the bricks and paint it.
Old 05-26-2012, 04:36 PM   #12
The spacing in those bricks looks to be quite wide,so i would use a closed cell backer rod and just leave about a 1/2 inch to use a caulk to finish it,the backer rod comes in various sizes so you'll have to measure and see what size will work for you ,or you may have to use various sizes,i'll attach a link for the backer rod so you have an idea of what it is,i don't know if home depot or lowes carries it but you can try there.
http://www.bestmaterials.com/Backer_...FQUEnQod6lptYg
Old 05-26-2012, 04:39 PM   #13
Sorry i forgot to include the link for the mortar in a tube,you should be able to get this at either HD or Lowes.
http://www.kk.org/cooltools/archives/004031.php
Old 05-26-2012, 07:54 PM   #14
Oh boy... Maybe ill hire someone to do that for me. Lol. Thanks for the input. Anymore suggestions would be great. Once I repair the spaces , can I just paint ovr it or is there something else that has to go on to?
Old 05-26-2012, 09:43 PM   #15
No nothing else has to be done but paint it after it dry's.
Frame out basement half wall diyinwi Remodeling 6 04-03-2012 10:08 PM
Putting a 'decorative' brick wall in basement - weight issue? jefferyscott Remodeling 4 02-27-2012 12:10 PM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 01:04 PM
Question regarding adding a stud wall to a brick structure jcieutat Building & Construction 0 12-15-2009 08:41 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
