Bag Concrete - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-14-2012, 04:18 PM   #1
bag concrete
how any bags would it take for a small slab 6by8
reneecr is offline   Reply With Quote
Old 05-14-2012, 04:20 PM   #2
hi is none there
Old 05-14-2012, 04:22 PM   #3
hi meant is anyone there
Old 05-14-2012, 05:03 PM   #4
Rewards Points: 1,294
give people a chance to answer. This is not a help hotline staffed by paid operators. It is a help group that other diy'ers and pro's hang out on in their free time. It may take someone some time to answer your question.
danpik is offline   Reply With Quote
The Following 2 Users Say Thank You to danpik For This Useful Post:
Ravenworks (05-14-2012), user1007 (05-14-2012)
Old 05-14-2012, 05:06 PM   #5
OK, I just did some research for you. Check this link. http://www.sakrete.com/products/calculators.cfm
You will need the thickness as well as the length and width
Old 05-14-2012, 05:12 PM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Sounds like you may be new to the whole internet thing?
Either way, there are MANY websites with concrete calculators. A search is all it takes.
More examples:
http://www.quikrete.com/Calculator/Main.asp
http://www.concretenetwork.com/concrete/howmuch/calculator.htm
- Build Well -
Old 05-16-2012, 10:47 AM   #7
World's Tallest Midget
Mort's Avatar
Rewards Points: 692
It calculates out to a little over a half yard (figuring a 4" thickness). If you have short-load concrete companies in your area, your back and arms will thank you if you just get it from a truck. Those calculator thingies tell me its 27 80# bags, which will take all damn day and likely result in a crappy finish since it could get away from you if you aren't on the ball.
Our ready mix company has a 1 yard minimum (and I've hauled that for people making hot tub pads and what not), so they could either haul back the extra or you could make your slab bigger. My feeling is that any more than 8-10 bags sounds way too much like manual labor, which I try to avoid like the plague.
I hate signatures.
Mort is offline   Reply With Quote
Old 05-16-2012, 11:00 AM   #8
joed's Avatar
Rewards Points: 12,426
Or you could go with something like we have around here. Two options. Ucart concrete. The have large trailers that can hold up to 1 yard. YOu haul it with your car or truck and return the empty trailer. Or we have truck that have the ingredients separate and mix only what you need on site. They have a meter and you pay for what you need.
Old 05-16-2012, 05:16 PM   #9
Mort's Avatar
Rewards Points: 692
Yeah, I forgot about that U-Cart stuff, one yard at a time. That's what I'd do. Mixing concrete by hand sucks.
I hate signatures.
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 12:32 PM
Need concrete tips and suggestions spaceman spif Building & Construction 4 10-05-2011 09:08 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 01:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 11:12 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
